Paint and body suggestions...
Old Oct 6, 2006 | 11:29 PM
mybabyisa79's Avatar
mybabyisa79
5th Gear
Default Paint and body suggestions...
ok heres the scoop, im 17 working on a 1979 corvette i got a couple years back. the paint is less then perfect and i finally got a lil extra cash so ive decided to strip and paint the car. its my first time doing anything of the sort, let alone on a corvette, so gimme some tips here...what kinda paint to use, one step or two step, best way to strip the chrome off the car, do i paint the car with hood and doors on or off?...and/or anything else you may deam helpful. thanks alot.
Old Oct 7, 2006 | 02:27 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Your going to paint it yourself? Do you have any experience painting a car?
Either way, I suggest you getting the book:
"Automotive Paint Handbook" by John Pfanstiehl. Its the one that has a C4 on the front cover. There is A LOT to learn about doing body work and paint. You will spend probably 90% of the time sanding and filling because that is the MOST IMPORTANT thing to do before spraying a drop of paint on it. The body has to be absolutley perfect.
As far as stripping...its a debate between stripper and a razor blade or sanding. If it was me, I would sand. Make sure you use a good wax/grease remover on the body before starting to sand or you will just imbed it more and could possibly have problems later with the paint.
Get a good book to read as a first step. Research it and do it it the right way!
Old Oct 7, 2006 | 08:43 AM
bondoboy's Avatar
bondoboy
Using a single stage paint works fine, but with a metallic, basecoat is easier. Removing every piece of trim will make a nicer paint job. If you are painting the jambs, take the hood and doors off. If not, leave them on and tape the jambs up.
Old Oct 7, 2006 | 08:47 AM
sly vette's Avatar
sly vette
Tech Tips >> C3 Related Tech Tips >> Corvette Body & Paint Repair Basics
Find all of this under other at the top of the page
Old Oct 7, 2006 | 11:24 PM
Mark G's Avatar
Mark G
For a newbie, I think using base/clear is the way to go. You WILL have imperfections and probably some bugs, etc, let's face it. With base/clear, nearly all imperfections can be sanded and buffed out leaving a near-show quality finish.
If money is tight, there are a lot of "Universal" urethane clears and 2K primers on the market that aren't significantly less expensive than premium brands and work/last great. They will give you 80-90% of what the "Premium" brands will, from my experience. Evercoat, for example has decent primers and clears. You can spray universal urethane clear over PPG Omni, or Dupont Nason colors. I've used lots of "Universal" urethane primers and clears in the last few years and I've been impressed with the quality. Use them on my own vehicles along side the more expensive brands. A lot of shops use them too. A lot of guys in the biz think some of the no-name universal 2k primers are as good or better than top name products. The technology is "out-of-the-box". Of course, if money isn't an issue, definitely go ahead and use a name-brand system.
Good luck,
Mark G
Old Oct 9, 2006 | 07:32 PM
mybabyisa79
5th Gear
alright new problem, what is the trick to getting the old front bumper off? ive looked at my haynes manual and loosened every freakin bolt on the front end, but it just aint comin loose. is there a simple way to take the whole assembly off with a few bolts? maybe a website with a better diagram of how it works?
Old Oct 9, 2006 | 08:10 PM
crazcorkath's Avatar
crazcorkath
Do you have an assembly instruction manual? That will have needed info . Kathy
Old Oct 9, 2006 | 08:11 PM
slowup's Avatar
slowup
dont paint it. Just use the cash u have now and work on the motor. Motor first, then paint. Unless u have a nice motor already.
Old Oct 9, 2006 | 08:29 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You! You! Is it that much harder to type three letters instead of one?
Old Oct 9, 2006 | 08:36 PM
slowup's Avatar
slowup
U gotta be kindding me. U mean to tell me its hard for U to decipher U from you?
Old Oct 9, 2006 | 08:51 PM
wnmech's Avatar
wnmech
Removing your old front bumper cover is not really a bad job. I am assuming you already have the lower valance removed. There are about 20 3/8 socket nuts holding the cover on. If you have a universal joint and a series of extentions and can manuever your hands into tight spots it wont be hard. The nuts are bolted to straps that go all the way around the cover. There is a bumper cover support on each side of the cover remove both of them. I believe they use 9/16th head nuts and bolts. If you go to ecklers on line catalog it will show you a picture of the strips that the nuts attach to.If I remember for the nuts under the headlight doors you must raise the lights either with vacumn or reaching under and just pushing up the doors. Good luck
Old Oct 9, 2006 | 09:54 PM
Bob Onit's Avatar
Bob Onit
Originally Posted by I'm Batman
You! You!
I believe the y should be in lower case in this situation
Yawn................
Old Oct 9, 2006 | 11:06 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
No, I know exactly what YOU mean...it just looks uneducated.
Call me a grumpy old man...but it bugs me.
Old Oct 10, 2006 | 05:32 PM
l88rocket's Avatar
l88rocket
Checkout Maaco.The one here in my town does real nice work.You get a base/clear paint job for less than 3g.
To Paint and body suggestions...
