Clutch adjustment
Old Oct 9, 2006 | 02:07 PM
'Bochawa72's Avatar
'Bochawa72
Default Clutch adjustment
I took out the shifter linkage to get my headers and sidepipes on and I think I might have re-installed it wrong. Now when I shift I have to press the clutch ALL the way down into the floorboard. Before there was a lot of clearance at the bottom end of the pedal. I've fiddled with it a bit but can't seem to figure it out. How do I fix this?
-CR
Old Oct 9, 2006 | 02:26 PM
Bob Onit's Avatar
Bob Onit
-CR
Basically the rod needs to be longer
Loosen the two 9 1/6 nuts and and move the rod keeper forward (towards the front of the car)
You should have about an inch-to an inch and a half or free play in the pedal before you feel any restiance
