Intake and Carb Advice
Old Oct 10, 2006 | 02:48 PM
asianlimodriver's Avatar
asianlimodriver
Default Intake and Carb Advice
All,
I have a 72 with basically stock 350 270hp motor. The cam was recently changed, but I'm not sure of the specs. There is a little lobe to the cam that smooths out when the engine gets warm. I'm planning on changing the intake and carb and need some advice. I've seen all the threads and it's greek to me. I was told that the Edelbrock Air Gap manifold is the way to go with a Demon carb. Will this set up fit under my stock hood, even with buying a drop air cleaner. Any help would be appreciated. If you could give me part numbers of your setups that work that would be great.
Old Oct 10, 2006 | 11:00 PM
litevette's Avatar
litevette
Originally Posted by asianlimodriver
All,
I have an Air Gap and Spped Demon. Even though I have the L88 hood (long style) I think I may have clearance issues. It looks to me like you have a stock small block hood which is even lower than mine. But there was another post here a while back where some had ran the same with success.
Old Oct 10, 2006 | 11:10 PM
MartyW's Avatar
MartyW
All,
Thats the same setup I have at the moment. Just switched to the Demon carb though, but it is running awesome. I definately had to have the twin turbo hood for clearance issues.
Old Oct 11, 2006 | 01:13 PM
asianlimodriver
Default Need Intake and Carb Advice
It looks like you guys have either LT-1, BB hoods or 1973 or later C3's. It appears from the threads that the later C3's have more clearance. I was wondering if anyone with a 1968 - 1972 C3 with the stock small block hood is running an Air Gap manifold with a Demon carb. If so, what air cleaner? Part numbers of the manifold and carb would be helpful. I definitely don't want to waste my time buying anything that won't work.
Old Oct 12, 2006 | 02:01 PM
asianlimodriver
Any input from a 71 or 72 C3 owner? Really need help here since I'm planning on buying the new manifold and carb this sunday at the Pomona Swap Meet.
Old Oct 12, 2006 | 03:24 PM
ED DINAPOLI's Avatar
ED DINAPOLI
The air gap will not fit under a stock 72 hood
Old Oct 13, 2006 | 04:28 PM
asianlimodriver
Any suggestions on intake and carb since I cannot go with the Air Gap?
Old Oct 15, 2006 | 06:29 PM
litevette's Avatar
litevette
You can probably get away with the Performer. Was good for 12.6's in my car.
Old Oct 15, 2006 | 09:55 PM
Kid Vette's Avatar
Kid Vette
I would recommend this.
Holley 6210 Spread Bore, Weiand 8004 Action +Plus. Will fit under any stock Corvette hood with the stock air cleaner
To Intake and Carb Advice
