bigblock question
Old Oct 10, 2006 | 03:14 PM
Enersis's Avatar
Enersis
Default bigblock question
i might not keep my 383 and return it, and get a 454 big block
what will i have to change, will the tranny be fine, i think i have a th350
Old Oct 10, 2006 | 03:26 PM
ImBatman's Avatar
ImBatman
Trannie will be fine but you will have to replace all of the pulleys and accessory brackets. Other than that it is a bolt in installation.
Old Oct 10, 2006 | 06:01 PM
Chilli's Avatar
Chilli
The TH350 will definitely FIT, but I'm not totally sure it'll hold together (depends on what you plan to do to the 454, I guess). As far as telling it apart from a TH400, I think the TH400's pan has one more bolt than a TH350 (14 vs. 13????); others here will know for sure. Funny you should be contemplating this - I've got a 454 that I'm thinking of selling and getting a respectable small block instead.
- Chilli
Old Oct 10, 2006 | 06:05 PM
72 LT1's Avatar
72 LT1
Chilli, I think your the first person I ever heard that HAS a bigblock and WANTS to go smallblock!! I've got to ask WHY??
Old Oct 10, 2006 | 06:39 PM
gmg1977's Avatar
gmg1977
thats cool that you are putting in a big block. Im glad Im not the only one crazy enough to pull a perfectly good small block and shoving in a behemoth.
Old Oct 10, 2006 | 07:19 PM
71 Green 454's Avatar
71 Green 454
Add me to the "Small Block Preference List".
The 454 BB is too much engine for me...my '69 350/350 4 speed was perfect!
Old Oct 10, 2006 | 08:54 PM
jerrylee's Avatar
jerrylee
Add me to the list...
Old Oct 10, 2006 | 09:04 PM
blue427's Avatar
blue427
frt coil springs,probably radiator
Old Oct 10, 2006 | 09:38 PM
gator79's Avatar
gator79
tell me he didn't just say that
Old Oct 11, 2006 | 01:30 AM
gmg1977's Avatar
gmg1977
no such thing as too much power. Especially with gas on its way down. Woo hoo $1.89 per gallon!
Old Oct 11, 2006 | 12:27 PM
Chilli's Avatar
Chilli
Certainly a legitimate question. The story is as follows; Originally, I bought the 454 for my '72 Chevelle (still need a few pieces such as pulleys, oil pan, valve covers, headers, push rods - actually, that's about it). About a year later I find a great deal on a '79 Vette. I bought the Vette and the Chevelle is now for sale. I was going to finish the 454 and put it in the Vette, but it looks like a TON of work and headaches. Please correct me if I'm wrong, but it looks like I'll go through the following if I put the 454 in the Vette that won't be necessary if I stay small block;
- taller hood ($$$$)
- replace front springs
- replace TH350 with TH400 (and shortening driveshaft)
- replace rad and fan ($$$$)
- spend piles of cash on keeping the rear end together
- go insane trying to squeeze in 2" primary/3" collector headers.
I salute everyone who swaps a big block into their C3, but it looks like more time, money and insanity than I can handle.
- Chilli
Old Oct 11, 2006 | 12:37 PM
bashcraft's Avatar
bashcraft
I'm swapping a 454 into my '69 right now and it's not that bad, but I have a 4 speed. So far the only problem I have is valve cover clearance, but I need to use tall covers because of the solid roller cam requiring the use of stud girdles. Most people won't have this problem.
I have pulleys and an alternator bracket coming from Summit. Should be here today so I'll let you know if they work. Other than that, I'm going to try and use the original radiator. If it won't cool it, I'll have to get a bigger one. Oh, I also have an aftermarket L-88 hood.
All in all, I'd say go for it. There's no comparison between a small block and a big block.
Old Oct 11, 2006 | 01:46 PM
gator79's Avatar
gator79
they fit, it was easy you just need the body off
Old Oct 11, 2006 | 01:54 PM
bashcraft's Avatar
bashcraft
I have Hooker sidemounts with 2 1/8" primarys. They fit with lots of room. And I didn't have the body off.
Old Oct 11, 2006 | 01:59 PM
FRANKENSTEIN4x42000's Avatar
FRANKENSTEIN4x42000
The TH350 will hold up just fine if it's built right, i am running a 600hp 502 in my truck turning 50" tires no problems at all. also as a bonus for the TH350 is more horsepower to the wheels 20 to 50 depending who you talk to.
enjoy
J-P
Old Oct 11, 2006 | 05:22 PM
72 LT1's Avatar
72 LT1
Chilli, I thought that you had bigblock installed and you were looking to swap it for small block. I can understand trying to save money/work with in a budget. I was thinking the same thing when I bought my ZZ4, instead of a 454 h.o. crate engine. But come to find out, I bought new headers, new radiator and core support, new flywheel and clutch, and am completly going thru suspension rebuild/upgrade w/new coil springs ect. Other than the initial price difference between the 2 engines (about $1400) I've ended up spending almost the same money anyways. I allready have LT1/ bigblock hood. Live and learn.
Old Oct 11, 2006 | 05:35 PM
Chilli's Avatar
Chilli
How much are the LT1/BB hoods going for? I thought I'd be saving a lot of money by staying small block, but now I'm starting to wonder. The 454 I'm building should offer about 450 hp and about 500 tq. (that's my GUESS) - it'll be a very streetable engine, but I still worry about breaking gears, twisting half shafts and spitting out u joints in the Vette. I can afford to put in solid Spicer u joints, but carbon fibre half shafts are a bit pricey by my standards.
To bigblock question
Old Oct 11, 2006 | 05:46 PM
Chilli's Avatar
Chilli
Holy crap, what did you do to a TH350 to make it stand up to that engine?
Old Oct 11, 2006 | 05:54 PM
FRANKENSTEIN4x42000
I would like to take credit for the build of the tranny but i can't, this tranny shop races his own BBC camaro 1000hp or so with a TH350, i started to talk to him about my "special application" he told me "i will build you a 350 and give you 2 years warranty" i told him if it last one season i would be happy, wells it's been 3 years, i have overheated the poor thing a couple of times but it's still running. Needless to say i will have him build me a tranny for that new vette i got
Keep in mind the Vette is not a big heavy beast to move, also the tires will break loose with too much power, my truck has traction for the most part so it's really hard for the tranny to be stuck in the middle.
J-P
P.S. even tough it's 3 years old it probably has no more than 8 hours of actual use, mind you every hour has been hell for it.
Old Oct 12, 2006 | 06:53 AM
bashcraft's Avatar
bashcraft
Unless you run slicks, that's not enough motor to break anything.
