Top 3 solutions--reverse lights
Old Oct 10, 2006 | 08:48 PM
foundvettelifeisgood's Avatar
Default Top 3 solutions--reverse lights
What are the top 3 reasons why reverse lights go out on a manual tranny? Assume bulbs are good.
What's the first place (easiest) to check?
Thanks.
Old Oct 10, 2006 | 09:17 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Backup switch would be the first place I would go to. I am assuming you still have the Muncie style transmission. This is the pics that I have left of my backup switch. Hope this helps some.
Old Oct 11, 2006 | 10:05 PM
genuine1980's Avatar
genuine1980
Assuming the bulbs are good. I would say either the switch is bad. Or The wire got cut. Or The linkage from the switch to the Tranny got diconnected.
Old Oct 14, 2006 | 04:50 PM
The thin metal rod in the right side of Eddie's pics was disconnected at the switch. The rod goes through a metal plate toggle, and is held by a spring snap (that is long gone). I tried to buy the connector at 2 parts stores and the closest thing was a C snap ring. The rod should probably be drilled for a cotter pin. Anyone know where to get this clip?
With it attached, the lights work fine.
Old Apr 30, 2014 | 12:03 AM
JGallo71's Avatar
JGallo71
Thanks for the pictures!
My linkage to the switch was installed upside down!
Got it to work again!
Old Apr 30, 2014 | 09:59 AM
jnealg's Avatar
jnealg
http://www.zip-corvette.com/catalog/...itch-rod-clip/
To Top 3 solutions--reverse lights
