Grinding/rubbing noise
Old Sep 16, 2001 | 09:50 PM
Ron 75 L48's Avatar
Ron 75 L48
Default Grinding/rubbing noise
I have a low grinding/rubbing noise that sounds like it is coming from either the drive shaft or one of the half shafts. The sound doesn't happen all of the time. I usually hear it after I have driven the car for 30 min or more. I really notice it when I take it out for a good run on some country roads where I can open it up on the straight stretches and I have to brake a lot for the curves. I am guessing at the source of the noise. Any ideas what may be making the noise?
Old Sep 16, 2001 | 11:40 PM
wombvette's Avatar
wombvette
Default Re: Grinding/rubbing noise (Ron 75 L48)
Common symptoms for rear clutches. The 75-79s also have a problem with rear shaft wear which contributes to the clutch problems. Check the rear closely for shaft recession, and change the fluid and additive.
Old Sep 17, 2001 | 12:05 AM
krafty79's Avatar
krafty79
Default Re: Grinding/rubbing noise (wombvette)
I agree with wombvette, had same problems (almost), and changed rear end fluid.. Go to the GM dealer and spend the $$ for the right stuff (posi fluid) as its different from wal-mart stuff... THere is no plate on the rear end, take out the plug and use a suction device (i.e. drill pump) with a clear tube to get the old fluid out. Make sure to tilt the vehicle left side up and right side up to get the fluid out of the axle housings (not a lot of fluid in the cavities, but enough).. I think I had to buy 3 bottles of juice and used 2.1...
good luck.
Old Sep 17, 2001 | 12:09 AM
JB's Avatar
JB
St. Jude Contributor
Wombvette's right on. I had a very similar conditions--kind of a groaning/rubbing noise after a run of more than 20 minutes at highway speeds, sounded worst when turning. Changed out the fluid in the pumpkin, put in two bottles of GM posi-lube additive, did some figure eights in a parking lot. Next long run there was no noise. Big relief, because the guys here had suggested it might be something more serious in the differential if the fluid change didn't help.
JB
'78SA
Old Sep 17, 2001 | 02:51 AM
OzVette75's Avatar
OzVette75
At the risk of sounding repetitive, drain and replace your diff fluid!
I was a skeptic when I had exactly the same symptons, started doing the sums for a new diff...... :rolleyes: :mad
Replaced the diff oil and voila! No more chattering/grinding..
IT WILL WORK! :D
Old Sep 17, 2001 | 08:45 AM
Ron 75 L48's Avatar
Ron 75 L48
Thanks for all of the responses. Of course I was assuming all of the worst case senerios and all of the $$$ I am going to have to spend on this! I see about getting the differential fluid changed out this weekend and hopefully that will take care of my problem. Again thanks! :cheers:
To Grinding/rubbing noise
