Water Pump Question
Old Oct 12, 2006 | 09:26 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Default Water Pump Question
Quick question on the heater hose connections. Which is the pressure side, the 1/2" fitting near the side inlet or the fitting on the intake?
Old Oct 12, 2006 | 10:24 PM
SIXFOOTER's Avatar
SIXFOOTER
the one on the intake
Old Oct 12, 2006 | 11:30 PM
ratflinger's Avatar
ratflinger
Thanks, that's what I thought, it seemed logical, hotest water to the heater core but I had a panic attack since I usually screw these things up the first time around.
Old Oct 12, 2006 | 11:47 PM
SIXFOOTER's Avatar
SIXFOOTER
welcome, there is nothing special in that line so I am not sure it really matters which way you connect it, unless the nipples on the core are different.
To Water Pump Question
