Steering box lube???
Old Sep 17, 2001 | 12:13 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Steering box lube???
Whats the best way to look inside the steering box to check the lube. Should the old lube be cleaned out first?
[Modified by 71,454,4spd, 10:25 PM 9/16/2001]
Old Sep 17, 2001 | 02:07 AM
MARKUS_P's Avatar
MARKUS_P
Default Re: Steering box lube??? (71,454,4spd)
There are three screws on top of the steering box.
Normaly you remove the screw next to the driver and the screw next to the front of the car, press in the lube with the help of a press and wait until the lube is forced out through the other screwhole...
You should have a lithium based grease, sometimes called chassis lube, in your steering box. I do not recommend using oil in the box, because this will increase the chance of a leakage...
I can get you the number of the grease if you need it, but I´ll have to search for it..
Concerning your question, normaly you don´t have to change the lube, but for checking I recommend unscrewing one of the bolts on top of the gear box, BUT NOT THE ONE IN THE MIDDLE!!, this is a adjustment screw.
then use a screwdriver and ckeck out how much lube is in there.
Old Sep 17, 2001 | 02:13 AM
LAvetteman's Avatar
LAvetteman
Default Re: Steering box lube??? (MARKUS_P)
Thanks Markus, I checked, theres lube in there. I can't be certain how much unless I could actually see inside. I'll leave well enough alone.
Old Sep 17, 2001 | 09:19 AM
madvette74's Avatar
madvette74
i ned to know what kind of lube, i noticed yesterday my is starting to leak.. any help with this would be great
Old Sep 17, 2001 | 02:30 PM
theandies's Avatar
theandies
Default Re: Steering box lube??? (madvette74)
Here is the part number GM #12377985. Go to any GM dealer and they should have it. This is a grease gun type tube so either you need a grease gun or some other way to get the grease in the steering box. Look for the post from a few weeks ago for more information on this subject.
John
[Modified by theandies, 12:31 PM 9/17/2001]
Old Sep 18, 2001 | 02:01 AM
MARKUS_P's Avatar
MARKUS_P
Here´s the link
http://forums.corvetteforum.com/zerothread?id=140527
Old Sep 18, 2001 | 04:55 PM
madvette74's Avatar
madvette74
thanks a lot for the link
To Steering box lube???
