4-7 swap cams, tuning, performance, chips, etc.
so as long as I have the engine out, and swapping trannies and heads and all sorts of crap around...I need some advice as to what to do about the cam, if anything,....
I am considering a 4-7 swap in firing order as the new LS engines have that....and it's common enough to be dooable from some grinder....
SO, what specific advantages to a 4-7 swap, as I beleive that ZZ cam is more a PIA than it's worth, and I"m NOT PAYING TPIS some 400 bux for a lousey chip....so what grinder is good at the 4-7 swap and making a cam that's fairly easy tuneable with a MAP system?? if not, I may in the radiator changes just include a over top air induction and change in rad angle to accomodate the hood clearance, and switch to a MAF type system to simplify tuning......
anyone with suggestions???
the entire engine is coming out along with tranny doing a swap to a 200 4r and ditching that damn 700r4, i'ts missed it's last shift for me....
about 200 lbs of car weight is coming off with these proposed swaps straight off....
SUPPOSEDLY
they smooth out the engine, make a bit more power.
SUPPOSEDLY
but no way I 'm having that radical a lift anymore, ...but then again when I rip the engine out again...SOON, I am taking the rad support out, and changing the angle, further forward on bottom, further back on top, to allow room for an up and over airlcleaner assy....so that may include a MAF, and if so, well....maybe that will cure some problems and lemme keep the ZZ9 cam....at any rate as long as the engine is coming out, the tranny is in for yet another round of work, or the way I"M leaning is total replacement with 200 4r, and maybe better luck....
hopefully I can keep down time to less than 2 months....eh??
murphy and all that...
I figured moving the spark and fuel around by physically moving the wires was more cost effective than reprogramming the thing.
Anyway the only change on a carbed motor is too swap the 4 and 7 spark plug. I expect with the fuel injection you need to move the fuel injection too so it fires at the right time.
Guru, you are missing something here, the CAM has to change sequence so the intake and exhaust are firing opening in CORRECT sequence....as what you are saying, they would be 180* out of sequence, don't forget the cam rotates at 1/2 crank speed, so therefore with your conclusion there the valves would be timed in the exhaust stroke remember
intake, down stroke, intake valbe open....
compression....all valves closed, piston moving up....
power, all valves closed...firing power somewhere near top of stroke...
exhaust....ex valve open, intake closed, piston on way up to puch gas outta there, then the intake opens on some sort of overlap, whatever the cam design allows, and we back to sucking intake of fuel/air....
so it's 4 strokes/cycles for every ONE opening/closing of any valve....
so the piston does 4 trips for every valve opening/closing........
so if you don't change the cam profile, you firing the plug on top of the exhaust stroke.....ain't a gonna work so well....
try it on a carbd engine...see what happens.....
