the last time i needed to jump the battery, of course it was raining. hook up the cables, get into the seat and of course the cables pop off, get out ,get in , pop off @!!xxzz^^**!! NEVER AGAIN. just run # 0 wires from the battery terminals through holes in the bat box. silicone the openings or use grommets if time permits. use the rear factory tie down bracket for your terminal mounts. since i did this i found that there are sexier terminal blocks made for golf cart charging systems but that would mean you must always have your cables with the end on them in the car. ]
