big block with holley air filter question
Old Oct 17, 2006 | 10:56 PM
bondoboy's Avatar
bondoboy
Default big block with holley air filter question
What is the part number for the air filter for the open element? I am using the base and stud for a big block on my 71. A 14x3 is too tall where the stud isn't long enough. A 14x2.5 is not tall enough and the lid hits the air horn and it won't seat. I assume there is a size in between around 14x2.75. Thanks for the help.
Old Oct 17, 2006 | 11:08 PM
Ironcross's Avatar
Ironcross
AC 212 is the BB part number. A solution to your short stud is to remove it completely and then use an appropiate length 1/4 USS bolt in place of the stud.
Old Oct 17, 2006 | 11:46 PM
1972warship's Avatar
1972warship
If you want a K&N here is a 14x2.8125 inch tall filter....part number from jegs 599-E-3742.
Old Oct 18, 2006 | 12:28 AM
bondoboy's Avatar
bondoboy
Thanks a lot.
To big block with holley air filter question
