small block exhaust
Old Oct 18, 2006 | 08:41 PM
elecriciandude's Avatar
elecriciandude
Default small block exhaust
Went to check my doughnut on the exhaust first thing I found was Bubba's washers. With that out of the way,are the Vette exhaust manifolds interchangeable with other years Vette/Chevy? 72 sb,a/c,.
thxs,Terry
Old Oct 18, 2006 | 10:28 PM
novavet's Avatar
novavet
all small block manifolds are about the same the only differents is some dump stright down or out the back and then you have what some guys call the ram horne manifolds but they all fit a small block
Old Oct 19, 2006 | 12:27 PM
markdtn's Avatar
markdtn
The manifolds used on small-block C3 vettes do interchange basically with all SB C2 and C3 vettes and some mid-and-late 60s passenger cars. They are all of the Rams horn design (except like '80 up that are tubular) They do not interchange with 67-72 trucks that are rams horn but have a different direction on the outlet. All C3 manifolds have 2" outlets. Some early C2 Hi-Po manifolds have 2 1/2" outlets. C4 manifolds are tubular and have a 2 1/2" outlet and can be used in a C3 if you fabricate headpipes. Hope that helps.
Are yours cracked? Can't you remove the studs and get new ones?
Old Oct 19, 2006 | 07:54 PM
elecriciandude
one`of the ears is broken off of the right one so i know it's toast,go figure,thxs,terry
Old Oct 19, 2006 | 08:16 PM
mr303's Avatar
mr303
There are left and right hand side manifolds and yes they are different!
To small block exhaust
