No ignition when key turned
But when I turn the key to ignite the engine, nothing happens; no clicking, no turning over, nothing. It's as if the circuit is completely open.
I also replaced the shifter cables, but made sure to make any necessary adjustments with the new ones. So, could my problems be with the neutral safety switch, or could one or both of the fusible links be bad, even though the harness is new?
Any and all musings will be seriously entertained......thanks.
One other thing, there is a relay on the firewall next to the wiper motor; I believe it has something to do with the T.C.S. circuit. When I have the ignition "on", the relay warms up and I hear a click coming from it, and the Dark Blue wire from the sending unit on the right side cylinder head, leading back to the TCS relay also feels hot to the touch. I have replaced this relay previously because the Pink/Black wire had fried all the way from the sensor to the relay and on to the junction block at the firewall. Any ideas.
So....new problem....the starter bendix doesn't engage the flex plate. Does anyone know if I have to add more shims, or what? I have a shim in place now, which is what the starter was originally equipped with. FYI, I replaced the original flex plate with a TCI one.
I thank you for any advice ahead of time.....
I was bringing a set of jumper cables with me, because every time it happened I could jump and it would fire up!
Yes, if you have an automatic, the Neutral Safety Switch is located adjacent to the shifter. It's half moon shaped with four wires, depending on the year. The wires that control the starting sequence are the 2 purple wires(in front of the switch). When the ignition switch is flipped to the start position, 12 volts flow from one purple wire to the other to energize the circuit. The Neutral Safety Switch itself is very simple, but reproduction units run anywhere from $64 (Zip Corvette), to $75 (Corvette Central). Mine was "shorting" because the contact between the two purple wires was constant, whether the slider was forcing them together or not. I opened mine up very carefully by prying the 2 metal hold down clips (part of switch base is metal hold down) located on the slider side of the switch. I used a pair of channel locks and placed one jaw on the bottom of the metal plate, and the other on the edge of the clip, and without squeezing, shifted the channel locks in an arc to force the clip to open up enough to allow the whole thing to come apart. Do not open the clip all the way since it might fatigue and break. Once you are done cleaning, inspecting, and fixing the switch, use the channel locks in the same way to put it back together; just do not squeeze too much, just enough to get the clip to hold the switch together. But if your Neutral Safety Switch is good, then perhaps all it needs is to be aligned properly. Just undo the four screws holding the shifter in place, and turn it sideways to expose the 2 screws that hold the Neutral Safety Switch in place. Loosen the front one, and just loosen the rear one slightly; then lightly rock the switch along its pivot while holding the ignition switch in the start position. Don't give up if the starter doesn't engage right away, since this is a very tedious process. You might also have to loosen the rear switch screw some more, if you don't succeed at first. Also, make sure the slider does not disengage from the pin that move its when the shifter is moved. If indeed your switch is good, then the starter should engage.There is a relay in the console, but I believe that it's for the A/C, but I'm not sure. I'll look it up later and if it's something else, I'll give you a post.
Just in case, I would also check the ignition switch (but it's a PITA). I believe that mine was just a little bit out of adjustment to where the slider that actuates it was not moving properly through its full range of motion.
Sorry for the wordiness, but I hope this sheds some light......
Later......
...... :o
I wouldn't be surprised if it was taken apart previously......It was like the last owners had a contest to see how many things they could unscrew and break and then use rusty wood screws and tape to put back together.
