Coolant Leak Question
Old Oct 19, 2006 | 11:29 AM
genuine1980's Avatar
genuine1980
Default Coolant Leak Question
Weird thing I noticed...
I never see collant leaking under my car when it's off, and I let the car idle on my driveway and I don't see anything leaking or any puddles.
But whenever I start the car cold, I notice that it leaves a small puddle of collant on the ground... I can't tell where it's coming from. The puddle makes it appearance around where the pump is.
I also noticed that I've been needing to add coolant sometimes.
Any suggestions?
Old Oct 19, 2006 | 11:36 AM
PETKAH's Avatar
PETKAH
Default Weep hole
Under the water pump there is a weep hole that lets coolant out
when need be - usually a small amount. It means that the pump
could be going, or there is a problem somewhere in the cooling system.
Old Oct 19, 2006 | 11:39 AM
DR.Jay's Avatar
DR.Jay
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Time for a water pump. The leak won't get better.
Old Oct 19, 2006 | 11:46 AM
genuine1980
Originally Posted by DR.Jay
Thanks for the good info.
What exactly is a weep hole and what does it do?... I understand the fact that it lets a small amount of coolant out when need be.
But when is that? If the pump is going, how do I tell? I am pretty sure it's a pretty new pump.
What other probem could be in the system?
The coolant is clean, I "think" the pump is pretty new. I run Dexcool and the I don't think the radiator is having issues. Engine stays cool. New Heater Core... Lines are clear. New Thermo. Intake man. looks clean... no coolange sludge or scaling.
Any ideas? Or is it pretty certain that I need to replace the pump.
Old Oct 19, 2006 | 01:19 PM
PETKAH's Avatar
PETKAH
Default Weep hole = seal defective
According to the Haynes manual - if coolant leaks out of the weep hole
... the seal in the water pump is defective and the pump should be
replaced. (In large quantities)
Need to drain cooling system, remove fan/shroud, drivebelts, etc.
Unless you want "original" go to NAPA, Advance, etc with the unit
for a replacement. Ideal time to detail that part of the engine, too.
Old Oct 19, 2006 | 02:37 PM
jlaw68's Avatar
jlaw68
make damn sure you tell them its for a vette or they will give you a regular small block water pump and you wont be able to see your timing marks. im going through that problem now. thinking about taking it back and saying i had problems with it and getting the right one.
Old Oct 19, 2006 | 02:39 PM
genuine1980
I guess I should take my old one off and say "here I want this exact one" right
Old Oct 19, 2006 | 02:40 PM
3rd_Vette's Avatar
3rd_Vette
My original water pump was still fine at 70,000 miles. I bought a new one when we did the crate motor.
Actually, the only somewhat major things that I have done on my car since new has been a carb rebuild6 years ago on the q-jet, new brakes @70k but really didnt need it (they were just 26 years old) and Shocks. I had the starter rebuilt at 67k and that is it. My 80 has really been a great reliable car and very fun to cruise.
Old Oct 20, 2006 | 11:22 AM
genuine1980
Well if the water pump pissing a little bit of coolant at startup means a new pump... then I guess I need a new pump.
Anyone have any idea how long I can get away with not replacing it before it seriously goes bad?
Old Oct 20, 2006 | 11:25 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
you'll be on the side of interstate 80 somewhere answering that one...
Old Oct 20, 2006 | 11:27 AM
genuine1980
I had to chuckle when I read this...
It is Murphy's Law isn't it.
Old Oct 23, 2006 | 07:13 PM
genuine1980
OK well I just noticed that my car is leaking coolant when its just sitting there... I've had it on stand for about a week cause I'm doing other things to it, and I noticed a small coolant puddle (maybe the size that 20 or so drops would make), on the drivers side just below where the water pump is.
I looked up and saw that it is dripping on the corner of the lip-corner of the oil pan... obviosly coolant isn't dripping from there, but I tryed to trace it up further and I can't find anything (that I can see visually anyway)... I felt all around the water pump and didn't feel any moister.... I'm lost!!!
Where is this leak coming from?
Now I dont know whether or not I need to even get pump.
Old Oct 23, 2006 | 08:25 PM
SmokinBBC's Avatar
SmokinBBC
The leak could be coming from loose/cracked hoses. Is it leaking from the thermostat housing? What about water pump bolts? Leak from intake mainfold?
Based on where you see the coolant (at the lip of the oil pan), look to see if it is leaking from the water jacket plugs. They are right above the oil pan on both sides of the engine. When flushing the system, the plugs are removed to drain the coolant from the block.
Do you have access to a coolant system pressure tester? It can be rented (for free) from autozone. Pressurize the system and look for the leak.
I used one about a month ago to find a leak. Turned out to be a heater hose.
Old Oct 24, 2006 | 02:39 AM
Tony S's Avatar
Tony S
The weep hole or 'tell-tale' hole in a water pump is designed to let the coolant out when the water side seal is leaking. This stops it leaking past the oil seal and into the water pump bearings which would damage them.
Old Oct 24, 2006 | 11:31 AM
genuine1980
I don't see any leak from any hoses... It's def not from the Thermo housing.
Could be water pump bolts... I saw a leak there once and I tightened that bolts to stop it.
Not the water jacket plugs... these plugs are located further back from where I am seeing coolant on the oil pan lip... I am seeing it near the timing cover.
I think the pressure tester it something I will look to doing.
Old Oct 24, 2006 | 11:32 AM
genuine1980
I thought it was this... but I can't find the weep hole and when I felt all around the pump I didn't feel wetness...
Old Oct 24, 2006 | 12:10 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default weep hole
The weep hole will be in the water pump casting just below where the shaft extends from the casting. Don't know about you 80 specifically, but a mirror might show you the hole. Had a small leak on my 85 once, all factory original several years ago. The leak was from the water pump gasket on the passenger side mounting of the engine. To put a new gasket on an 85 involves removing a lot of stuff to just get to the water pump. Removed the pump and installed new gaskets. About a year later had another leak, this time from the weep hole in the pump. It was easier removing the pump the second time because I had done it just a year earlier.
Old Oct 29, 2006 | 01:49 AM
genuine1980
I think I've confirmed that my leak is not the weep hole, rather it seems that both mounting gaskets where shot and leaking. I've drained the system... flushed it. Removed the pump, cleaned it, and replaced it with new mounting gaskets. Also checked all hoses which are pretty new while doing the flush. Replaced thermo, and the housing gasket.
So with everything cleaned, checked, and re-filled... hopefully there is no more leak. We shall see.
To Coolant Leak Question
