What should the output voltage be?
Old Oct 19, 2006 | 01:28 PM
Ivan_the_Red's Avatar
Ivan_the_Red
Default What should the output voltage be?
Greets,
I have just rebuilt my alternator on my 82 and have a few questions about its performance. Since my battery was dead before I rebuilt it, I just reconnected everything and jump started it to get it running. After starting it I took my multimeter and probed the 'BAT' connection from the alternator and it showed a voltage of 11.46 which is low for a properly operating electrical system. Is this low voltage most likely due to the battery being dead or could there be another internal problem with the alternator. I rebuilt the alternator initially because of an even lower output voltage of about 9.1, I installed a new diode,regulator and brushes.
Old Oct 19, 2006 | 02:44 PM
wfo76's Avatar
wfo76
not charging, should be 13.8-14.4 volts
pull it and let autozone test it but don't let them keep it
get it rebuilt or just save it if its original
