Throttle Sticking
Old Oct 20, 2006 | 12:51 PM
abaumgar's Avatar
abaumgar
6th Gear
Default Throttle Sticking
I have a 1970 350/350 Fresh Rebuild: I bought a Stage II Quardra-Jet
from Jet performance in California. The throttle sticks when kicking in the Secondaries, raising the RPM to 1800 Plus. The only way to bring it
down, is to kick on the Gas Pedal. I can feel this spot in the Gas Pedal,
as I accerate up, and pass thru it as I go,
Anyone shed some light! Where is this coming from. Secondaries Sticking, or a Internal issue.
Al.
Old Oct 20, 2006 | 01:41 PM
Durango_Boy's Avatar
Durango_Boy
Al.
I used to have a setup with an aftermarket intake and an Eedelbrock carb on a Dodge motor, but I had a similar issue. Now, they may have nothing to do with one another, but the primaries would open, and just barely catch teh inside of the bore on the intake, and stick unless I goosed the pedal. It took me a while to decide what the problem was, and all I had to do was pull the carb, file downt he bore where it was hanging up and the problem was solved.
Old Oct 20, 2006 | 01:48 PM
PRNDL's Avatar
PRNDL
My throttle bracket on the side of the carb was getting hung up on the air cleaner base. Same symptoms as you: High idle could be knocked down by tapping the accelerator. Then I would remove the air cleaner and base to get a good look at the carb and of course, DUH!, I couldn't figure it out!! Finally a more methodical mechanic than myself showed me the marks on the bottom of the air cleaner base where the bracket was rubbing. Just requires some careful diagnosis, and it helps to have 2 people. (Oh, and the easy fix for me was bending the bracket a little bit from vertical so it doesn't rub on the base). Temp fix was to add a 2nd throttle return spring, but that wore out my ankle.
Old Oct 20, 2006 | 06:06 PM
694speed350's Avatar
694speed350
If you are using a brop base aircleaner check the bottom of it. the throttle bracket on my 69 would hang up was catching on the bottom of the air cleaner base.
Old Oct 21, 2006 | 09:59 AM
Durango_Boy
Another place to look is the cable itself. If the wire has a frey, it can catch on the sheeth too.
Old Oct 21, 2006 | 10:07 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I had a frayed cable coming out of the sheeth on the carb end. I replaced it with a new one and it was like a night and day difference. The go pedal was easier to move and I didn't have to blip the throttle like you are now.
Old Oct 21, 2006 | 02:17 PM
jpw73vert's Avatar
jpw73vert
you can also adjust the cable so that more of the sheath is slid forward, i.e., less of the cable is exposed. as others have suggested, sometimes the end of the sheath will catch on the bracket or arm on the carb that holds the cable.
Old Oct 22, 2006 | 03:25 AM
kb2fzq's Avatar
kb2fzq
Also check your hi idle mechanism for binds/bends/broken parts or springs missing...
Old Oct 22, 2006 | 01:08 PM
Durango_Boy
I guess the short answer is to look at everything for binding. Look at the manifold, base, throttle cable...everything. You shuld be able to make it duplicate the stick by hand just moving the throttle back and forth and 'feeling' where is holds up.
To Throttle Sticking
