carb base plate
Old Oct 20, 2006 | 03:58 PM
fugawi's Avatar
fugawi
Default carb base plate
can you change a base plate from a double pumper to a vac secondary to make a double pumper.i've got a 7779 base plate complete ,and metering plates with one float bowl. the carb to put parts on is a 80508 vac secondary. both are 750 cfm. would like to change to double pumper with minimal cost....
Old Oct 20, 2006 | 05:22 PM
fugawi's Avatar
fugawi
bump
Old Oct 21, 2006 | 07:55 AM
fugawi's Avatar
fugawi
anybody, beuller, beuller...
Old Oct 21, 2006 | 09:26 AM
Gordonm's Avatar
Gordonm
The bodies of the carb are also different. You would need a body from a DP carb also to make it work as a DP.
To carb base plate
