Low idle...
Old Oct 21, 2006 | 04:21 PM
jerrylee's Avatar
jerrylee
Default Low idle...
With about 300 miles on my rebuilt engine I finally solved the cooling issue now I just have a problem were the idle gets real low like she wants 2 stall when I'm sitting at a light or just idleing like when I'm getting fuel.......This only happens after a good hour n a half or so of cruising..Any ideas would realy help...Thanx...Jerrylee///
Old Oct 21, 2006 | 07:30 PM
icanfixitforyou's Avatar
icanfixitforyou
I had the same problem with my 383 stroker, it turned out that the pcv valve was causing a lean condition at the carburetor. We eliminated the pcv valve and all the weird idle problems went away. What carb. are you using? Mine is a Holley 750. I ran a 13.25 at the track before I trashed the rear end. Waiting on a new rear to arrive now.
Old Oct 21, 2006 | 07:51 PM
jerrylee's Avatar
jerrylee
I'm using an Edelbrock 800cfm-#1413..........
Old Oct 21, 2006 | 07:58 PM
Bob Onit's Avatar
Bob Onit
I would hope you replaced the PCV with a new one
Not wise at all to run without one...Not wise at all
Old Oct 21, 2006 | 08:01 PM
icanfixitforyou
I'll replace it as soon as I can figure out which one applies to my 383. At this time the supposedly "right" one doesn't work right. Any suggestions?
Jerrylee - sorry about hijacking your thread,
Lee
To Low idle...
