The swap is in motion.
Which is the correct big block motor mount?
Summit sent me the Energy suspension 3.1117G "GM early tall & narrow style engine mount"
Is that correct for a '74 454?
if not, what is the right Part number?
When you say correct, do you mean factory correct or just the best ones to get? I have a 454 in my '69 and just changed mine to poly motormounts made by Energy Suspension so hopefully I won't have to do it ever again. I'll check when I get home from work to see which ones they are and post it although the 3.1117 number sounds familiar. Anyway, they fit perfectly. :smash:
That is the set I have in my car, Energy Suspension Polyurethane with interlocking tabs. They are red right? You can almost see them in my sig pic. They fit great.
