Advice on frame off vs. frame on resto.
Would 3 to 5 more years become too late for the frame, even if kept indoors?
Am I overestimating the time to take the body off and restoring the frame and making too much over nothing?
Is it true some people suspect cars which have had their bodies lifted?
Is there really no right or wrong answers?
I think every car is different and needs to be evaluated by, condition (does the body need to come off?), your budget (a frame off will require more parts and labor), how it will be used (driver or show), and if you show it, how you want to be judged. Granted a lot of the work done on the '68 would have been easier if the body was off, but the owner made the decision to leave it on and in this case it worked. Just my .02
If you do a body off, will be still be willing to drive it in the rain or go down a dirt road?
Yes, it's possible in a winter but how much do you plan to work on it? Are you going to spend 8-10 hrs a day on most Saturdays and Sundays November thru April, or just a day here and there? What about evenings after work?
What kind of facilities, tools and experience are you bringing to the table? How fat is your wallet? Will you do most of the work yourself or send stuff out? Are you doing a restoration, or making mods? Do you have 2 stalls to dedicate to this project? Lot's of considerations.
I am in the middle of a frame-off on a '69 sb coupe (14 months so far) and plan to keep my car when I am done, so for me a frame off was the best choice. The garage gets too hot June-Sept to get very much done, so I really have about 8 months of work into it with a ways to go (still rebuilding chassis). I am replacing or rebuilding everything. The chassis is much easier to work on with the body off. I wish I was driving my car this winter (the real driving season here) but it will likely be another year before I finish this car.
Good luck, either way it sounds like you have a great start.
to do a frame off over the winter i think is very aggressive. i can easily see that project ruining a good marriage. the kind of guy that could pull that off is a retired guy with lots of time and money and power tools. Oh and a place to stash the body while he does it without taking his wifes spot in the garage.
i love to look at a sweet frame of restoration. especially when they put the mirrors under it at the shows. myself, i will be getting some por-15 with those special little daubers to get inbetween the frame and body.
i say drive the car now before the fossil fuels are depleted.
If I had 2 Vettes it would be an easy answer, drive one work on one. But back to reality!
Is this a one way street? Can't I do the frame a few years after I do everything else. A little backwards but I assume it will cut my time in half.
http://forums.corvetteforum.com/show....php?t=1530819
i am thinking the answer will be yes to your question.
i have a question... What does a frame off get me that i cant do with the body on?
cant replace body mount bushings.
cant sand blast the frame.
ok, what else?
A true un-touched original Vette that has been well maintained and not exposed to rust would be an example of a car that you would not want to remove the body.
Everything on the chassis is easier to work on with the body off, and the time saved here more than makes up for the time required to R&R the body.
If there are any body repairs needed, these are also easier with the body off.
Things that can't be done with the body on:
1) rocker channel repair, cleaning, anti rust application
2) replacing body mounts, shimming for fit, ride height, door alignment
3) cleaning and inspecting frame---repairs are much easier with the body off
4) Fuel and brake lines are much easier to repair/replace with the body off
If you're sure the frame is solid, if you like the looks of your rocker channels, like your fuel and brake lines, then don't pull the body.
So as stated in previous posts, it all depends on what you want/need to accomplish, what tools and space you have, how much time you have, and what work you can do yourself.
Keep in mind the body mount bushings are solid on the 68. Thus, there is no ride advantage to changing mounts like on a rubber mount car.
it will increase costs because you will most lileky have to redo certain items........if you want to take it apart fully you should follow how the factory built it.....any thing other then that will mean that you repeat the same steps twice and that costs time and money....but after all its your time and money so do what works for you.....
My frame was in good condition, just some surface rust. My body mounts and brake and fuel lines were also in good condition so I left the body on.
here are some before and after shots so you can see some results with the body on.
I cleaned and stripped the frame where I could get to it. I unbolted the brake and fuel lines but did not remove them. Then I painted the frame with por-15 and top coated with a satin black (also painted the brake and fuel lines). Since it's garage kept and babied now I don't think it will ever need the body completely removed.
If I were going to do a factory correct restoration then I think I would have needed to remove the body to get all of the colors and finishes correct.
Good luck with your project.
I pulled my body a 4 weeks ago and will have the body back on the frame in 2 weeks. (haven't been able to work on it everyday).
QUESTION IS.....do you have a heated garage? depending what you plan to do such as paint the frame, some paints can't be used in cold tempatures so doing it over the winter might not be possible.
I started doing a frame-on, but I put so much work into grinding, wirebrushing and painting the frame that it drove me nuts knowing I didn't do the last 10%. And the most important area to protect your frame is the top...and you can't get to that with the body on.
Go for it, just make sure you keep that fire lit under your **** to get it done....and keep the garage warm
I also have a 68 (my dream car) which I am doing the body off. I have pics of every step so e-mail me if you want any doogie1101@hotmail.com
-Brett
I started by tenting off the car and sandblasting underneath laying on my creeper, suited up with protective gear like an astronaut. I could only stand about ten - fifteen minutes of this crap at a time.
Once I got finished the job, I wished I had just done a frame off. The car looks like a frame off, but i know it's not.
For me the prime enjoyment is working on the car, improving its condition, and enjoying the satisfaction of the finished product.
For what it's worth, if you've got the room, do a frame off.
From my perspective there are a lot of things that you will probably be doing that would be easier with the body off. If I were painting the car and going to replace my engine, suspension, etc. I would rather remove the body than work around it because it would be easier overall. The problem with doing this is that when you get the body off you will want to fix everything while your there and as was mentioned earlier, get ready to spend $$$. Here's a few pics of my 10 month project.
Ditto MichaelG.
If you are building a driver and have a frame in good condition, clean everything you can reach from below, paint with POR15 and move on to the next area. i replaced the solid shims between body and frame with rubber mounts from a 73+ to soften the ride a bit.
