I just had a new Compressor and acumulator bottle installed. The air is cold but does not blow hard. Where do I start? How do I get to all of the duct work and vacuum lines? Do I have to remove the dash? I will be removing the dash to replace it as I go along w/ my resto but didnt want to take it off yet for fear that it will fall apart.
I did a search for this but could not find it. If there is a previous post link it to me.
In addition to Chevymans input, is your high speed switch for your blower working? If so, you either have a a clog at the evaporator or you are loosing air flow somewhere. Once you have solved the problem, add some chicken wire to the inflow area of the cowling to prevent leaves, etc. from entering the evaporator box.
