Front suspension odds and ends
Old Oct 23, 2006 | 04:44 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Default Front suspension odds and ends
1) the big bolt on the lower control arms has a weird serrated washer on it...but I can only find one of mine at the moment. Is that a normal hardware store item or am I going to have to order one from somewhere?
2) is there a specific up and down to the 460lb VB&P springs? They look symmetrical to me.
Old Oct 23, 2006 | 08:51 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
1) Not sure if you can pick that washer up at any store or not. Did you check the frame to see if it's still on there?
2) Spring can go in either way.
Old Oct 23, 2006 | 09:57 AM
NHvette's Avatar
NHvette
I have seen the serrated cupped washers at hardware stores ...
gotta look through the metal drawers of unique hardware ... not a Home Depot item.
Size might be an issue ... recall seeing them up to 1/2" - not sure about larger.
Strange that the washer goes under the head of the bolt ... doesn't
seem to do much since the bolt fits the hole pretty well.
Perhaps it helps to keep the bolt from tearing through the hole.
Old Oct 23, 2006 | 10:50 AM
Durango_Boy's Avatar
Durango_Boy
Batman - Are you finally getting that front end together? Can't wait to see it.
Funny how neither side of mine has that washer you speak of...what's it's purpose?
Old Oct 23, 2006 | 01:46 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That washer goes on TOP??? That would explain it...I haven't been able to replace the D/S bolt because of the power steering pump. I need to unbolt the engine and lift it a bit. I'll check that in a little while...thanks!
Matt, I got a wild idea yesterday and worked on it from midnight to 3am...
Old Oct 23, 2006 | 01:51 PM
Durango_Boy
Oh yeah...I've been there a few times, but lately I can't, with the lady friend wanting company around those times...
Old Oct 23, 2006 | 02:54 PM
Glassbowtie77's Avatar
Glassbowtie77
When I rebuilt mine I thought the washer was missing on the driver's side but it was stuck to the bracket hidden by years of crud.
Old Oct 23, 2006 | 02:55 PM
Durango_Boy
My question is does not having one pose a problem? I don't have either.
Old Oct 23, 2006 | 03:18 PM
Glassbowtie77
I would image they are there to prevent the bolt head from tearing through the bracket. These bolts get torqued to 95 ft. lbs. and the bracket seem get alot of stress on it as youv'e seen a number of times where the entire bracket tears off the cross member due a crappy weld job at the factory. I just repaired this very problem on mine. Iwould get the washers and install them if it were me, they are there for a reason. Zip sells them I believe.
Old Oct 23, 2006 | 03:27 PM
Durango_Boy
I'll look into getting a pair...what would they be called for ease of searching?
Old Oct 23, 2006 | 03:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Since they go on top, it shouldn't be a problem. The one that I haven't found is probably still on the bracket, wrapped around the bolt.
Old Oct 23, 2006 | 03:56 PM
NHvette's Avatar
NHvette
How I know they were on top to begin with ... note serrations in top of bracket:
http://nhvette.homeunix.com/ftp/in/front_gusset_06.jpg
Installed again (and slightly rusty):
http://nhvette.homeunix.com/ftp/in/lowerCA4.jpg
Note the large diameter bolt but washer has smaller than expected OD.
Old Oct 23, 2006 | 06:46 PM
Durango_Boy
Originally Posted by NHvette
Great looking gussets my friend...top notch work.
Old Oct 23, 2006 | 07:12 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
One day down the road I'm going to fully strip the frame, reinforce it, and have it dipped and powdercoated.
Old Oct 23, 2006 | 07:14 PM
Durango_Boy
You'll need something bigger than you're little oven for that my friend...
Old Oct 23, 2006 | 08:06 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Just a bit...
Old Oct 23, 2006 | 08:28 PM
Durango_Boy
Just a bit...
This one would work me thinks...
To Front suspension odds and ends
Old Oct 24, 2006 | 01:42 PM
Corvetteran's Avatar
Corvetteran
I've done a complette mechanical rebuild of my 'vette and the only place I found cupped-serrated washers was for the transmission mount to crossmember bolts. I found it odd that they were located here, since the Assembly manual depicts just a lock washer for these bolts; but hey......if that's where they were, who am I to say......
Old Oct 24, 2006 | 01:47 PM
Durango_Boy
You know, I was thinking about this a little more seriously last night, and a large oven for powder coating could actually be made. Let's speculate...
How hot will an average wood stove get? Maybe 450-500 degrees?
You could make a large wood chamber similer to a wood stove. Create a larger chamber directly above the wood fire chamber. Heat transfer and convection would heat the secondary chamber to an average temp close to that of the wood fire. Keep it fed and even, and the coals would keep it hot.
Sound good? Lets get started.
Old Oct 24, 2006 | 02:28 PM
NHvette's Avatar
NHvette
For P-C large pieces, they use UV lights.
D-B:
Thanks for the compliment, but that framework was done
soon after getting my welder ... and it was high school since
I had welded previously. So, the gussets are nice - but the welds could use improving.
I do like my front jack plate, though ... quite unique:
http://NHvette.com/ftp/in/frame_paint_04.jpg
