I made an attempt to remove my trailing arm bolts yesterday without much sucess. I thought before I got out the torch and hammer tonight, I'd ask the question. Is this the right approach?
Both bolts are frozen in place.
Many here will agree, that cutting it out with a good sawzall blade is the way to go. Using a 12" high quality metal or bi-metal blade, and cutting between the shims will take time. That's a grade 8 bolt and is HARD!
Happy sawing...
Eddie
Sawzall. Many threads on this subject. Very common problem. Cut them out with a sawzall. Should take 2 or 3 bimetal blades and they should be out in 1/2 hour or so.
Some use a sawsall with a fine blade. While others cautiously use a torch, make sure you have the shims out and mark there location. Have you trid power blaster spray? I would spray the heck out of them. A pia job it is. Use never sieze when you put it back together.
Regardless of the method you choose, tape the shim packs together and mark them. They have to go back in same places in order for the rear toe to get back to approximately where it was when you removed them. It'll help on the drive to the alignment shop.
If not, when you put your SS Shim's in (im sure you will get them ), just make them equal on both sides of the trailing arm and you should be fine getting to the alignment shop.
Well I just did it 10 minutes ago. Took the day off to talk to the insurance Co, Body shop for quote and get my car off the floor after it was knocked off the jackstands. Working on the car for therapy. I had a long sawsall blade in the box and figured I would give it a shot. Took 5 minutes to cut both sides. Used a Remgrit blade (8" abrasive blade for cast iron) and pb blaster for lube. Walked right through it. I thought this was hard reading all the posts on it but really, Less than 5 minutes for two bolts.
Thanks for the tips guys. I'm off to buy a new sawsall tonight (lent the old one and never got it back). Hopefully the shims are there to count!
Go to Home Depot for the sawzall and pick up a Remgrit 8" blade while you are there. I got my shims out and only used 1 blade and it is still good. Use lots of lube too!
My most memorable task on my car... thought I'd go the cheap route and bought some Wal-mart 12" cheapo blades... thought I'd die of a heart attack before getting the bolts cut...middle of summer 100 degrees...the blades kept hitting the back of the frame and bending...oh my gosh. Had absolutely NO hide left on my knuckles.. Finally broke down and went and bought the good blades from Home Depot and hacked right through them.
The Remgrit blades have an abrasive on them, no teeth. I first used them to cut a 4" iron soil pipe to tie in a bathroom drain. Went through my 5 pack of bimetal lenox blades and didn't get it done so I went to Home Depot and bought 3 8" Remgrit blades. It went through the pipe like butter. One of these was the one I had left to use today. The only way to go. I have seen a lot of posts on this and never seen them recommended so I thought I would share this valuable information. I remember when I cut the ones out in my 72 with bimetal which was recommended on the forum. Took 3 hours to get out one side.
I am the rep for Lenox blades in the Mid Atlantic area. Yes the Remgrit blades will work fine on the bolts. A toothed blade will actually cut better and faster than a grit edge blade. The grit is Tungsten Carbide. Therefore they are more expensive than Bimetal blades but they will last almost forever. A good 9 inch Lenox Bimetal blade with 14 or 18 teeth will make quick work of the trailing arm bolts with the proper speed and lubricant. An 8 inch works perfectly so you have to grind off an inch of the tip to fit in just right. I have cut many hardened bolts with just one blade in my many demos of the product.
Cutting Cast Iron soil pipe, a grit edge is about all that will touch it. Most all the grit edge blades are made by Remgrit regardless of whose name is on it.
Funny, all i use is lenox blades...get that at work CHEAP
Sorry Gordon, I know you sell them but, the Lenox that were recommended on the forum is what I tried to cut the bolts on the 72 with, They did cut it but I had much better luck with the 8" Remgrit. They are more expensive but it walked through the bolt in a couple minutes with 1 blade. It was a 63 vs a 72 so maybe the bolts were different material or grade. In your defense I would also like to say the milwalkee bimetal blades I tried before I got the lenox knocked off the teeth in about 1 minute flat
