Can't Get it into Reverse
Old Oct 23, 2006 | 11:52 AM
depdep3's Avatar
depdep3
Default Can't Get it into Reverse
I have a 71 four speed and can not get it into reverse. It has been a little "sticky" lately, but yesterday it was impossible. I am pretty sure it is the linkage, but I have never adjusted it before on any car. Going into 1st to 4th is fine, just reverse. The transmition seems fine while driving, just can not get it into reverse.
Old Oct 23, 2006 | 11:58 AM
genuine1980's Avatar
genuine1980
You might not need adjustment...
First check that the reverse pull lever is acutally working...
Unscrew the shifter ball. Take the reverse pull, spring, and rod out.
With this removed... try putting the car in reverse. If it does you want to inpsect why the rod is not being pulled high enough to let it go in reverse while connected.
If this isn't the problem... check underneath the car and see if anything is binding up the linkage... have a friend shift the car through the gears while you inspect.
Old Oct 23, 2006 | 11:59 AM
genuine1980
I question for you.... can you get the shifter in the rev position, and it just doesn't enguage? Or you cant get the shifter into that position at all?
Old Oct 23, 2006 | 12:17 PM
depdep3's Avatar
depdep3
Can't get it in the position at all. It will go full left to right, but not up (into reverse)
Old Oct 23, 2006 | 12:32 PM
genuine1980
Ok so you are able to get it over to the left far enough that it would normally go up into reverse... if you are absolutly sure about this then it isn't going to be the first part I said with taking the ball off.
Go under the car and check for binding like in the second thing I said.
If that still isn't it... try moving the car a little back in forth (while off of course) while trying to get it into rev....
I'm trying to think of things to check before saying... "ok you need a rebuild" or "need to make linkage adjustments".
Old Oct 23, 2006 | 12:33 PM
blue by you's Avatar
blue by you
check to make sure the cable is connected at the sterring column
Old Oct 23, 2006 | 12:35 PM
genuine1980
This is a manual. There is a cable going to the column? I never saw one on mine?
Old Oct 23, 2006 | 01:56 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
try putting the muncie in second before going into reverse, this should clear the gears and allow you to put it into reverse, if not its time to get underneath the car for a visual inspection of the linkage and shifter
BTW i do this all the time now out of habit, from a previously corrected problem
cheers
tim
Old Oct 24, 2006 | 05:51 PM
bluthundr's Avatar
bluthundr
Yes, this happened to my 76 after being parked for a long time.
The reverse lock cable goes from your reverse linkage to a lever on the steering column. When you park the car in reverse and then take out the key, this lever actuates a cable and locks the transmission in reverse. If the cable is bent/rusted/etc, it may make your transmission either stuck in reverse or unable to get into reverse.
http://www.zip-products.com/Zip/prod...AFA7BFDD1736D0
Old Oct 24, 2006 | 10:22 PM
genuine1980
Yet another part missing from my car. Thanks
To Can't Get it into Reverse
