Srarter problems 80
Old Oct 25, 2006 | 12:00 PM
joefloyd's Avatar
joefloyd
Default Starter problems 80
I need some info. about the starter on 80. I have an 80 with headers and a 4 speed trany, the other day the temp. was in the mid. 80 s I drove about 50 miles at 70 + mph. and the temp. gauge held at 180 to 190. The car ran well until
I stopped at a light and I stalled it. I tryed to re start it and there was no activity from the starter. Two nice kids gave me a push and I popped the clutch and it started. I drove home and shut it down for about 20 min. After sitting 20 min. it started with no problem. There is no heat shield on my starter (does it come with one?) I think the problem is heat, maybe from the headers, or no shield on the starter. If some one has had this problem your input will be appreciated
Thanks Joe
Old Oct 25, 2006 | 12:48 PM
Ratsirt's Avatar
Ratsirt
Install a mini starter. I had same problem and after installing Powermaster 180. No more starter problems.
Old Oct 25, 2006 | 12:59 PM
baja216's Avatar
baja216
I had the same problem. I installed a heat shield/wrap on my old starter and it kind of helped out. I finally got sick of worrying and installed a new starter and the heat shield and I haven't had any problems since.
Old Oct 25, 2006 | 04:08 PM
Boofers's Avatar
Boofers
You might get away with just cleaning the contacts inside the starter solenoid & make sure all the electrical connections are tight & clean of dirt & oxidation.
Old Oct 25, 2006 | 05:48 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I added a starter heat shield to mine. No problems since.
To Srarter problems 80
