Check engine light ?
Old Oct 26, 2006 | 10:30 PM
copter's Avatar
copter
Default Check engine light ?
Ok,this started happening last winter and now that the weather has started to cool off it's started again.We have had a couple of mid 40's out during the night.When it gets cool like this my check engine light will come on after the engine is up to operating temps and it will stay on for 2-3 minutes and go off.By that time I'm home from work so I don't know if it would continue the same thing.It doesn't do anything to the preformance of the car.By the way this is an 82 all stock except for dual exhaust
Old Oct 26, 2006 | 10:38 PM
SIXFOOTER's Avatar
SIXFOOTER
Hmm, computer is not happy about something. You need to check what code it is showing
Old Oct 26, 2006 | 10:41 PM
copter's Avatar
copter
It is one of those things that will only show up when the light is on?The codes I mean.
Old Oct 26, 2006 | 10:43 PM
jayr's Avatar
jayr
Test scan is the only way to tell. I did have more than my share of map sensors act up in the spring and fall with damp cool weather.
Old Oct 27, 2006 | 12:07 AM
wombvette's Avatar
wombvette
I would check the EGR sensor.
Old Oct 27, 2006 | 12:40 AM
copter's Avatar
copter
Thanks,Refresh my memory what is the EGR senser?
Old Oct 27, 2006 | 12:56 AM
jayr's Avatar
jayr
Got a EGR readout to the computor on my wifes 96 park ave. System 11 computor. When the light goes on it does not go off until you clear
codes with the scanner. Unless you want to disconnect the battery and lose all your radio settings. I don't think our vette EGR are electronic
as far a position information to the computor.
Old Oct 27, 2006 | 01:24 AM
copter's Avatar
copter
Light goes off by itself
Old Oct 27, 2006 | 04:21 PM
spedaleden's Avatar
spedaleden
I would check O2 Sensor or just take the light bulb out
Old Oct 27, 2006 | 04:41 PM
copter's Avatar
copter
I like that idea
To Check engine light ?
