differential lubricant
http://www.traction.eaton.com/prod6.htm
Also when I checked into using syn oil years ago I called Tom Watt and an engineer at US gear, I don't recall his name. They both advised against syn oil in the differentials, why I honestly don't recall. I figured they were either building drag race diff's or designing gears so they'll know what works in use.
I'd be interested in an assay / analysis of a conventional versus synthetic differential gear lube, as well as an assay of the GM additive... my uneducated guess is that the additive is heavy on Molybdenum and Zinc.
Anyone seen that sort of info?
"What type of lubricant and limited slip additive should I use with my newly purchased Eaton Limited Slip Differential?
Eaton strongly recommends utilizing an API-GL5 approved Mineral-Based 80W-90 Axle Lubricant and one 4-oz bottle of Limited Slip Additive (GM or Ford)."
But you're right,..those engineers at Eaton are probably a bunch idiots. And the failed posi units that were returned for warranty reasons or otherwise, were simply tossed into the big Eaton trash can out back. I'm sure the failures weren't studied as a part of Eaton's R&D program. And I doubt it ever occured to the engineers at Eaton to test the use of synthetic lubes with their product.
After all, why would a company spend all that time and money on R&D, since we know more about Eaton products than the mush-headed engineers at Eaton.
And those millions of Eaton posi units installed on GM cars through the years that ran a trillion trouble-free miles using conventional gear lube,..well, we know how to make it better.
Eaton,..it's a crummy company anyway. And engineers,..what do they know.
