Tricks to determine coolant cracks?
Old Oct 27, 2006 | 09:08 AM
Blues77's Avatar
Blues77
Default Tricks to determine coolant cracks?
Replaced head gaskets after overheat.. lots of white smoke. Im still getting lots of white smoke after replacement. Is there some good tricks to determine if its the heads, block or intake manifold? My intake manifold is aluminum..not really sure where to start.
Old Oct 27, 2006 | 09:10 AM
SIXFOOTER's Avatar
SIXFOOTER
Machine shop can magnaflux them. If your still sucking coolant you may have warped the head(s). Pull them back off and have them checked.
Old Oct 27, 2006 | 09:40 AM
gerry72's Avatar
gerry72
Run the engine with the radiator cap off and check for bubbles in the radiator. If you see bubbles, do a compression test of the cylinders to determine if you have a leak into the cooling system. If all the cylinders check okay, you could buy a CO sensor pack from NAPA that will tell you for sure if you if you are or are not getting combustion gasses into the coolant.
You could also be dealing with the aftermath of coolant in the exhast. Depending on how long the engine has been running since, it could just be the coolant continuing to burn off in the exhaust.
You'll also want to keep tabs on your oil condition. If you see any signs of a milkshake on the dipstick, you may be seeing coolant going into the oil.
Most of the time, it's the heads that warp in a severe overheat, especially if they're aluminum.
Old Oct 29, 2006 | 10:31 AM
Blues77's Avatar
Blues77
Thanks for the answers. My heads are iron. The only aluminum peice is my intake manifold. Wouldnt an aluminum intake manifold give out to high heat before iron heads? Im just hoping its not the block, as id like to keep the bottom in the car.
Old Oct 29, 2006 | 10:46 AM
Durango_Boy's Avatar
Durango_Boy
I had the exact same problem six years ago when I rebuilt my motor. All of a sudden, I started getting endless plumes of white smoke/steam from ONLY the passenger side sidepipe. I had a lot of spare parts, so I replaced a lot of things. I replaced the intake. No change. I replaced the heads one at a time, testing after each change. Nothing. I used new gaskets every time, and proper torque specs. No change.
I was left with one option. A new block. Luckily I had a spare engine that I used to build this one. The block was a core, so I dropped it off and the heads along with the old block. I wanted them both tested, because if in fact the old block was okay I wanted to use a Corvette block, and not a truck block.
Turned out I had a crack. So, I rebuilt the entire motor. Long story short it sounds to me like you have a cracked head or block.
Old Oct 29, 2006 | 10:02 PM
marshrat99's Avatar
marshrat99
Could be the following, easy to worst:
1) head gasket
2) cracked heads
3) cracked block
My guess would be No. 2 -- cracked heads. Anyways, you're going to have to pull off the heads just to replace the head gaskets. Would be worth your while to have the heads magna-fluxed and planed even if you're only replacing the gaskets. Check the heads first !
Old Oct 30, 2006 | 01:46 PM
Durango_Boy
Does your car have true dual exhaust? Is there an H or an X? If they are dual, do you get white smoke from both or only one tip?
To Tricks to determine coolant cracks?
