Cruise Control 78
Old Oct 27, 2006 | 11:53 AM
FireMedic5's Avatar
FireMedic5
Default Cruise Control 78
I found out why my cruise control was unhokked from the throttle. When hooked up, it holds the throttle wide open. I noticed that the air bladder sucks all the way when the engine is running. What would cause this. Is it a vaccum problem, there seems to be plenty vaccum; or is it a mechanical problem?
Old Oct 27, 2006 | 01:01 PM
markdtn's Avatar
markdtn
Sounds like the vacuum is either hooked up wrong or the cruise module is defective. Be sure you don't have straight engine vacuum to the bladder.
Old Oct 27, 2006 | 01:08 PM
ESU's Avatar
ESU
I had the same problem on my 79, the two hoses on the transducer were reversed, almost killed me.
ESU
Old Oct 27, 2006 | 09:52 PM
FireMedic5's Avatar
FireMedic5
Thanks, whats the best source for a vaccum diagram?
Old Oct 27, 2006 | 10:04 PM
ESU's Avatar
ESU
The AIM or the service manual, try reversing them, worked for me. The fact that it kept it at WOT means the transducer is probably good, just routing the hoses. There is only 2 on the transducer so its not hard to reverse,
ESU
PS just re read your post, mine stuck at wot when engaged, are you saying the bladder sux in when engine is on at like idle without the cruise engaged? If so then its hooked up directly to a vac source.
Old Oct 27, 2006 | 10:31 PM
canucbuck's Avatar
canucbuck
Inside the transducer there is a plate that engages when the cruise is activated. The plate when engaged should have clearance between it and a another plate under it.(very primative design but hi tech in its day) A common problem is the shaft that is joined to the plate becomes worn allowing the two plates to come in contact with each other which causes the car to go flat out. Best thing to do is buy one rebuilt for around $100.00. Solved my problem.
Old Oct 28, 2006 | 08:17 PM
FireMedic5's Avatar
FireMedic5
ESU
Yes it sucks all the way in at idle.
Correct me if I'm wrong, but on my cruise "booster", there is only one vaccum line leading to it. I pulled it off with the car running and there is a pretty strong vaccum. I tried to see where the vaccum hose went, but it went back under the driver's side fender and I didn't have time to trace it the other day. I assume if the vaccum is hooked up wrong, it would be on the other end of that hose.
Old Oct 28, 2006 | 08:20 PM
FireMedic5's Avatar
FireMedic5
Forgive my ignornance, but what is the transducer, is that the unit that links directly to the throttle. I've always referred to that as the booster, probably incorrectly however. Thanks
Old Oct 28, 2006 | 08:46 PM
ESU's Avatar
ESU
I'm pretty sure there are 2 hooked up to the transducer. Its the part that the speedo cables go into. On my 79 was is a little larger diameter than the other. I'll check my car tomorrow to be sure. I'll also pull my service manual/AIM and see, maybe I can scan it and email to you.
ESU
Old Oct 28, 2006 | 08:49 PM
ESU's Avatar
ESU
The transducer is the large silver metal part that is in the drivers side fender area, near the master cylinder and windshield washer tank. 1 speedo cable goes into it from the tranny and then one comes out and goes to the speedometer. It also has 2 vacuum lines hooked up I think,
ESU
Old Oct 28, 2006 | 09:32 PM
FireMedic5's Avatar
FireMedic5
The part that I was looking at has the rubber bladder that connects to the throttle linkage and has one large vaccum tube coming out of the back, right from the center. There may be another line from the bottom, but just one from the back. The one from the back causes the bladder to suck all the way in, when disconnected, the bladder is inflated, just as when the car is not running.
Old Oct 28, 2006 | 09:41 PM
ESU's Avatar
ESU
That part is called the servo. Follow the vac lines to the fender well , drivers side and see where it goes. Or go to any of the vendors like midamerica or corvette central and do a sdearch for cruise transducer, it will give u a picture of what to look for,
ESU
Old Oct 28, 2006 | 09:51 PM
FireMedic5's Avatar
FireMedic5
Ok, thanks. Correct terminology goes a long way. It's a lot easier to point and say "That thing"
Old Oct 28, 2006 | 10:09 PM
ESU's Avatar
ESU
Default see if this helps
ESU
Old Oct 28, 2006 | 10:35 PM
FireMedic5's Avatar
FireMedic5
Thanks for the diagram. I'll try switching those hoses and see if that fixes it.
Old Oct 29, 2006 | 08:31 AM
ESU's Avatar
ESU
Took me a while to get mine running, over the years prior owners really screw with things especially vac hoses for some reason, Keep us posted,
ESU
PS and look for a pink wire that goes into the fuseblock, mine was unplugged and wrapped up in the dash for some reason. At least on my car it was pink. I think the prior owner was looking to free up a slot in the fuseblock
Old Oct 30, 2006 | 10:39 AM
FireMedic5's Avatar
FireMedic5
According to the diagram, it looks like all the vaccum hoses are hooked up correctly. The two on the front can't be switched because they are different sizes and the larger one switched to the smaller one won't seal. Does that sound more like the transducer would be bad?
Old Oct 30, 2006 | 11:39 AM
theoUK's Avatar
theoUK
Your transducer's faulty, and seems to have stuck on "full suck"
Whip it out and see if you can coax it back to life - have a look here before you replace it with a new one.
To Cruise Control 78
