whats it worth?
Rebuilt stainless steel sleeved brake calipers and new master cylinder.
Rebuilt rear differential 3.70 gear set + posi and new side yolks.
New rear strut rods (VB)
New fuel pump
New timing chain
New oil pump (done with timing chain) new rear main seal.
New alum water pump
New Griffin alum radiator
New radiator hoses, T-stat, Heater core
Distributor rebuilt
Front suspension rebuilt with poly bushings, Big block springs (550lb), blistein shocks (front and rear), new tie rods, new idler arm.
New power steering pump and hoses
New Clutch (Luk)
No leaks
Lights flip up and down with no problems.
Stock rims
All emissions equipment present.
Have a peep
http://home.comcast.net/~bckauffman/Corvette.jpg
comments?
how about 8 -12k and hope for the best......i would expect at the lower end to be realistic but you never know
