RPO codes?
Old Sep 19, 2001 | 08:37 AM
Racer-X's Avatar
Racer-X
Default RPO codes?
Where can I find RPO codes on a '75? :flag
Old Sep 19, 2001 | 09:03 AM
Tom73's Avatar
Tom73
Default Re: RPO codes? (Racer-X)
If you have the original documentation that came with the car, you should be able to find them there. If not the only hope is to find a build sheet. One copy was glued to the top of the gas tank as the car went down the line. Would need to pull the tank to see if it is still there. More then likely the elements have gotten to it.
The build sheet was a multi-part carbon form. As workers used their copies on the line they would usualy throw them in the trash, but some would stick them in the car. They have been found under the rear carpet, in the seat springs, and under the dash in the wiring between the speedo and tach.
The RPO codes are not on a sticker like the C4/C5s have.
tom...
Old Sep 19, 2001 | 09:22 AM
GaryS's Avatar
GaryS
The "Genuine Corvette Black Book" by Michael Antonick lists all the options for the all the years. Other books have this same list.
Gary
Old Sep 19, 2001 | 09:25 AM
Astro7's Avatar
Astro7
Cruise-In VIII Veteran
try this link:http://www.idavette.net/facts/75.htm
To RPO codes?
