Rocker Arms
Old Oct 28, 2006 | 10:16 AM
toupstrio's Avatar
toupstrio
Default Rocker Arms
What is the differance between 1.5 and 1.6 rocker arms? How would I know whats better for me?
Old Oct 28, 2006 | 10:34 AM
Little Mouse's Avatar
Little Mouse
you will have to change pushrods to go with 1.6.
if you have say a lobe lift on your cam of 310 X 1.5=
4.65 lift same lobe lift 310 X 1.6 = 4.96 lift. if you
have an older factory cam with low lift the 1.6 rocker
would be more help then if you have a more modern high
lift cam.
Old Oct 28, 2006 | 10:36 AM
toupstrio's Avatar
toupstrio
lift cam.
Ok maybe you can help I am putting the comp cam xe268h in with vortec heads that have been reworked with larger valves and springs should I go with the 1.5 or 1.6 and buy new pushrods?
Old Oct 28, 2006 | 10:40 AM
Little Mouse
I believe the vortec heads are limited to 480 lift I think you
will be over your lift limit with a 1.6 rocker. did they modify
the heads fo more lift ?? I think that cam has around a 465
lift with a 1.5 rocker.
Old Oct 28, 2006 | 10:46 AM
toupstrio's Avatar
toupstrio
Yes new springs good up to 510 lift I would like to stay with the stock rocker arms are maybe some roller rockers if i can go with the 1.5 i will i was just curious if 1.5 would be ok.
Old Oct 28, 2006 | 10:52 AM
Little Mouse
thats what I would do just stay with the 1.5. roller rockers are
for stiff valve spring high rpm engines, there not much
help on a street engine.
To Rocker Arms
