Brake hat offset and rotor thickness?
Old Oct 31, 2006 | 07:02 AM
lvrpool32's Avatar
lvrpool32
Default Brake hat offset and rotor thickness?
Does anybody know what the stock brake rotor offset is?
and the thickness of our rotors??
cheers,
Nick
Old Oct 31, 2006 | 08:01 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Nick, The front rotors are 1.25 thick and the offset from the outer surface of the rotor to the outer surface of the hub is 1.846. The hub outer surface thickness is .390.
Old Oct 31, 2006 | 08:04 AM
lvrpool32's Avatar
lvrpool32
thanks!!
Old Oct 31, 2006 | 08:27 AM
mrvette's Avatar
mrvette
I dunno the exact specs but the mounting flange of the front/rear rotors is of two differant thicknesses....about 1/4 inch thick for the front, and maybe 3/16 thick for the rear....that makes them NOT INTERCHANGEABLE, as the offsets are too great for the calipers being fixed in postioin....they are same size otherwise ......
methinks someone specd a rong size hub back when, and whole bunch were delivered, and so it was just plainly cheeper to order another size rotor to cover the error, assign another part number and have done with it......
Old Oct 31, 2006 | 08:42 AM
BBShark's Avatar
BBShark
Nick, I sense a conversion project going on. If you are looking for some big rotors that will interchange with C3 rotors, look at Mercedes rotors from a 2000-up CL500. They are 330mm dia., 32mm thick (C3=32mm), 76mm offset (C3 78.6mm). They would have to be redrilled for the GM bolt circle but should fit. Brembo PN BR25578
The offset measurement (76mm & 78.6mm) is from the back of the rotor to the hat face. This is the more "normal" method of measuring offset.
Old Oct 31, 2006 | 09:05 AM
lvrpool32's Avatar
lvrpool32
yup, thinking of some nice 13" rotors (drilled/slotted) up front over the winter.
Had some good input from Kieth at Corvette Engineering, just wanted to get all the "right" info first.
Nick
Old Oct 31, 2006 | 09:16 AM
70 LS1's Avatar
70 LS1
Thats a good idea. I wish I had done that before doing my brakes.
What are you going to use for rotors and calipers?
Old Oct 31, 2006 | 09:18 AM
redvetracr's Avatar
redvetracr
Consider a two piece hat and rotor. You can get the "hat" from Wilwood and a (good and affordable) rotor from someone like Coleman or Wilwood.......
...redvetracr
Old Oct 31, 2006 | 09:22 AM
lvrpool32's Avatar
lvrpool32
Hi Howard,
do you happen to know what hat it is from Wilwood?? I have been on their website and seem to be going in circles.
I have already spoken to coleman, they can get me what ever I need.....
Nick
Old Oct 31, 2006 | 01:07 PM
lvrpool32's Avatar
lvrpool32
OK, what i have found.
Coleman sell an aluminum hat 1-7/8 offset (1.875) which is 0.029" more than stock. They sell a cast and a billet version and can drill them for 5 x 4.75 stud pattern
Wilwood sell a hat that is 1.88 offset (which is 0.034" more than stock) This comes 5 x 4.75" but the face is .25" which is thinner than stock.
Nick
Old Oct 31, 2006 | 03:20 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Doesn't wilwood make a rotor hit that is a direct fit.
Old Nov 1, 2006 | 01:52 PM
norvalwilhelm's Avatar
norvalwilhelm
The problem with hats and large rotors is the hats are small. Something like 7 to 8 inches in diameter and when coupled with a 13 or 14 inch rotor they look funny.
You really need a big 10 inch hat and I don't know who makes them this size.
To Brake hat offset and rotor thickness?
