Auto to Manual Trany Conversion Question
I've just completed the same swap in my '76, using a TKO-600 from Keisler.
My personal findings and cash savers were;
Made my own z-bar, brackets and linkages, except for the ball-studs (but I did have access to a lathe).
Bought a complete pedal assembly from ebay for $75 (installation does require removing the dash, but remember to remove the A-pillar trim sections, otherwise the dash top removal would be impossible!!).
Used an old 1978 borg warner bell housing, but got the faces checked by a machine shop for prallelism(?). It required a couple of thou' milled off the transmission side to acheive this (approx. $40).
Did the whole install myself, which probably took about 50 hours in total. Although, personally, I ended up spreading this over six months!
Who would have guessed that fatherhood would rob you of so much garage time!!!????
There is nothing severely technical about it. The biggest head burner is dialing in the bellhousing, but there's alot of advice written in different perpectives on this forum and numerous websites.
Good luck with your descision, if you want more, or clearer info on what I've mentioned, then PM me or post any questions here...
Cheers,
Douglas
Send me some specs on your car Year, Exact engine and rear end ratio.
I will send you a quote based on you car. This goes for any one else
interested in a kit from us.If we have several orders at one time all from
this thread we will make a considerable consideration on the price for you guys. I will need your forum name. If you want to make it easy go to our website www.keislerauto.com and fill out a request for quote and include your forum name in the text.
Thank You
Gene Charsha
Tech Sales
865-609-8187 ext 211
gene@keislerauto.com
Thank You
Gene Charsha
Tech Sales
I am definitely interested...What considerations can you make on price?
The note from maluminse, regarding the tunnel. I found that when I removed the original shifter assembly that there was a concaved area in the top of the tunnel that the shifter sat in. I cut this out so the top of the tunnel was flat but with a large(ish) hole in it. Once the transmission was in for the first time (second time was for keeps!) I could fabricate an aluminium plate to fill the hole and accomodate the lower boot assembly (it's in the Keisler kit) with everything lined up.
Are you interested in selling it?
Darrel1
Thank You
Gene Charsha
Tech Sales
Bernie
Scott,,,
Thx
Thx
Yes and no..... Pedals are the biggest PITA.
You can buy a z-bar frame bracket for a 78-82. It is a bolt in. Drill and tap 2 holes in the frame and mount the bracket. Make sure you get it lined up correctly or the geometry will be wrong and you will bend the bracket with pedal pressure. ask me how I know.....
Also make sure you get the correct clutch fork. The Lakewood GM fork will not work without serious modification. Again, ask me how I know.....
[QUOTE=slowup]Other than these issues my sap was pretty easy. If you do stay with mechanical clutch linkage do yourself a favor and buy the heim joint setup from speeddirect. It is pricey but when you compare it to the stock junk it is well worth it.
Good Luck!
BR
Bernie
