I have installed the gm serpentine kit I see the return hose connection on the power steering pump is differant a lot higher the original will not reach would like to know what anyone has done and since it is the return could a hose connector be used.Thanks for any help.
Go to any parts store, and they will sell you power steering return hose by the foot. Buy what you think you'll need, and install it accordingly using small hose clamps.
I know you mentioned a connector, but to be honest, being as cheap as it is, it's a better idea to replace the entire run of hose. That will ensure you have a fresh crack-free return line.
I'm having trouble remembering. Is the return line have a permenent fitting on it at the valve? Seems I thought it was a nipple too, but I could be wrong. Probably am.
I had the same problem. What I did was to remove the sheet metal "can" that encloses the actual cast iron pump. The can is basically the reservoir. Take the reservoir off of your original and install it on your serpentine pump. You'll need to buy a new set of O rings for the reservoir. Now your return line will be in the right place.
I'm having trouble following that...do you happen to have some pics to help clear that up?
