Pulse wipers for '74
Old Oct 31, 2006 | 04:11 PM
TG74's Avatar
TG74
4th Gear
Default Pulse wipers for '74
While the dash is out I would like to find way to add a pulse wiper function to the existing system if possiple. Does anyone know of a retrofit that will work with the old system? If not what would be required to change the system?
The installation of the 450HP LS1 from Turnkey and the Tremec 5-speed from Keisler is going well with just a few minor glitches. The engine swap project sort of snowballed on me and the car was stripped with the body left on the frame. I've added a 6 point rollbar, offset trailing arms, rack & pinion steering, upper control arms and coilover shocks from Speed Direct, side exhaust, Auto Meter Ultra lite gauges, tach & speedometer, upgraded the A/C, sprayed Lizard Skin in and out with kool it insulation sheets as well, an alpine radio with satalite, shaved door handles with door poppers tied into the security sytem and satalite tracker. A custom leather interior in Oxblood and Black was made by Al Knock for me using '82 seats. Also added an L-88 hood. I'm sure I left out something I changed or modified but that is most of it.
The '74 has never been hit (in the family since new) but needs a lot of panel alignment and fit work. I'm not sure what the exterior color scheme will be but probably black or other dark color with accents.
Thanks for any help with the wipers.
Old Oct 31, 2006 | 07:18 PM
TPI BOY's Avatar
TPI BOY
I would like to know also
Old Nov 1, 2006 | 11:28 AM
genuine1980's Avatar
genuine1980
Isn't that what the switch under the steering column is for? Just kidding. I just want to know too.
To Pulse wipers for '74
