Rim Back Spacing Question
Old Oct 31, 2006 | 05:19 PM
bence13_33's Avatar
bence13_33
Default Rim Back Spacing Question
What is the stock wheel back spacing on a 1976 Corvette? I'm thinking about getting a pair of Weld Pro Stars for the back to mount a pair of slicks on to replace my stock steel Rally rims and eliminate some rotational mass. I have a pair of polished 15x3 Centerline Autodrags for the front already. Thanks in advance
Old Oct 31, 2006 | 06:19 PM
goinbroke's Avatar
goinbroke
Stock is 4" I believe.
Old Oct 31, 2006 | 06:30 PM
mrvette's Avatar
mrvette
What ever you do, just do it smart....and keep the wheel centerline the same as what you got....you can use a tape, and I suggest you do....
wider wheels can go to 9.5 inches...that being 3/4 into inside, and of course 3/4 to outside....they will clear sway bars and frame...
assuming you move the ebrake bracket off the T-arm....
so you CAN get 10" of rubber on there without going crazy...
but you need spec the wheels and tires, and pay attention to the obvious....
destroying the wheel centerline IMO...and I suspect most engineers would agree with me....puts mucho more stress on the wheel hubs than I would consider reliable for a street machine...
Drag race ONLY, yeh, well maybe...usually no several lateral loading,....
I am one of the few bugs on this point, especially in the rear...as those hubs have no purchase on the lever...so they in trouble quick....
Old Oct 31, 2006 | 06:41 PM
bence13_33's Avatar
bence13_33
Yes the e-brake brackets are gone. I run 28x11.5x15 Mickey Thompson ET streets which is slightly less than 10" of rubber. I really just want to get the same exact 15x8 rim with the same backspacing....just in the Weld Pro Star style.
Old Oct 31, 2006 | 07:04 PM
mrvette's Avatar
mrvette
I make no statement aboutr various tire sizes, mounting, and so forth....i'ts all over the map.....there are NO consistant tires...
GENE
Old Oct 31, 2006 | 07:16 PM
bence13_33's Avatar
bence13_33
I feel like I am missing something here. I'm not trying to be difficult I swear . Now someone said that stock backspacing is 4". So if that is the case couldn't I buy a pair of 15x8 Weld Pro Stars with 4" back spacing and be good to go???
Old Oct 31, 2006 | 11:12 PM
capt.t's Avatar
capt.t
yes
Old Oct 31, 2006 | 11:28 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Slicks?? is your rear stock Shane??
Old Oct 31, 2006 | 11:36 PM
bence13_33's Avatar
bence13_33
I purchased the rear end off of mark (ML67). I believe for the most part it is stock with hardened yokes. I have run 28x11.5x15 Mickey Thompson ET streets at the track for quite a few passes with the old motor. I don't launch very hard at all and slip the clutch so that I don't shock the driveline. I think my best 60' time was 1.8 or so. I run them to keep my tires from coming loose when going through the gears. I'll probably put my ET Streets on the Pro Stars, right now I have 275/60/15 BF Goodrich radials because I had planned on bringing it to Atlanta with me but I never got around to it.
P.S. I do have halfshaft loops that Norval was kind enough to give me just in case things start breaking.
Old Nov 1, 2006 | 03:42 PM
yellow-fever's Avatar
yellow-fever
Default Back spacing of stock rims
I just had to go through a crash course on this when I ordered my new AR Torque Thrust II's for my 74. I wanted to stay with the stock wheel size and back spacing so I thoroughly researched the subject, including measuring the stock wheel myself. It turns out that although the stock (Rally) wheels on mid-70's Vettes are indeed 15x8 with 4" of back spacing, this is only the width BETWEEN THE INNER EDGES OF THE RIM. The wheel is actually 9 INCHES WIDE TOTAL, as measured from the outide edges of the rim. This means that there is a total of 5" of width on the OUTSIDE of the mounting surface, giving the rim one-half inch of "negative offset". If it had 4.5" of back spacing, it would be a "centered" rim and would have zero offset.
I also measured the clearance to the caliper with the rim on my car and I believe you would have clearance problems if you ran a rim with more than 4 inches of backspacing, unless you removed the e-brake arms.
Hope this clears things up.
Old Nov 1, 2006 | 04:33 PM
vetteaddic's Avatar
vetteaddic
You'll still might need a spacer for those wheels to clear the calipers,
I tried a set of the Cragar stars same as Weld and didn't clear,so ad that to your figures.I'm not 100% sure maybe 90%.
Old Nov 1, 2006 | 04:45 PM
VCuomo's Avatar
VCuomo
memphis03EB - So did you end up with AR TTII part number 5055861 rims?
Old Nov 1, 2006 | 05:06 PM
The Money Pit's Avatar
The Money Pit
I have Weld Draglites.The mounting flange on the wheel is flat,and will not clear the brakes without a spacer. I ordered 15x9's with 5 1/2 " backset,and installed a set of VB&P 1/1/4" wheel adaptors. This puts the effective backset to 4 1/4" (4" is stock) and my P295 50 15's fit completely under the fender with no clearance issues. (10" tread)
Old Nov 1, 2006 | 05:25 PM
bence13_33's Avatar
bence13_33
Maybe I'll just hold off on the rear rims then. I'm not sure that running spacers in a drag racing application is the best of ideas. Thanks for all of the help.
Old Nov 1, 2006 | 05:38 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've been using a set of 8" rally's on mine with the 10.5x28" slicks. If I'm not mistaken they measured 3-3/4" backspacing. That was laying a straightedge across the lip and measuring down to the center area. I moved the e-brake bracket and the slicks are pretty close to trailing arm and polish it slightly on the front edge.
I just took off the TTII's with 3-3/4" backspacing and they fit perfect. I just installed Cragar SS's with 4-1/4" backspacing and they are a PITA. Had to use spacers to clear calipers anyway but that got tire back away from trailing arm..which is stock.
You gotta be careful going to far inward unless you have a shortened spring and offset arms.
I have a buddy with some old Cragar Super Tricks that I was going to use, but they had 4.50" backspace and no way they would clear. Might have with offset arms....don't know.
Maybe this helps.....
JIM
PS- Bence-You living in Atlanta these days? I go there a lot for work..in fact I'll be there next Monday.....wanna meet up sometime?
Old Nov 1, 2006 | 05:40 PM
yellow-fever
Default Torque Thrust II part numbers
Since they were special-order custom-built wheels, I actually don't know the part number but they are model number CL205.
Old Nov 1, 2006 | 07:26 PM
bence13_33's Avatar
bence13_33
Jim:
I have been living in Atlanta for about 2 years. However I met a girl down here and she said that she'd be willing to move home with me...I'm moving home November 5th (this Sunday) otherwise I would have met up with you for sure. I'll be able to start drag racing and working on the car again once spring weather hits. Here's a picture of my baby (I'm sorry I love to brag about her, she's awesome).
To Rim Back Spacing Question
Old Nov 1, 2006 | 07:39 PM
nastee383's Avatar
nastee383
They have 3.5 and 4.5 backspacing. I would go with 3.5. That's if you can find any these days.
Old Nov 1, 2006 | 11:49 PM
427Hotrod's Avatar
427Hotrod
Hey she's a cutie!! Congratulations!!
Oh well....you'll be ready to bring it to the Forum Cruise In come next May right?? Finally?????
JIM
Old Nov 2, 2006 | 12:28 AM
gkull's Avatar
gkull
I have weld 10X15 with 4.5 BS with my 10X28 goodyear slicks. Without my 420# spring they would hit the stock 79 body. You would have to have modded fenders.
She is a cutie! It would be nice to be young again. I have a foxy 21 year old dau! She knows all about Alki injected dragsters and GoKart raced. She is a Snow board bum. I had High hopes for grad or medical school.
Now I just tell her it's just as easy to love a rich man as a poor one
The Wife (driving)and daughter in front of our house - Her Firebird
