AC Delco Battry Info 1978
I have to replace the battery in my 78 Pace car - Right now there is an Ac Delco professional 70-5yr in the car. What is the correct battery that is supposed to be in there??? Obviously I'm sure the original number is not available, but I'm sure that there is a replacement number that is for this car.. The Ac Delco rep sold me a 70-6yr which has more CCAs than the 5yr (about a 100) and the Ac Delco web site says 74-6yr. Any help is appreciated.
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
or a series 78 will fit fine, with the latter being physically larger. I have a '76 and am using the 75. You can get various cold cranking amps (cca's) and I suppect the original battery was around 500 cca's. Hope this helps.
Originally Posted by Jud Chapin
I don't know if you are looking for a Delco or not. In any event, a series 75
Be sure and get the right battery for the engine. I have a 78 L-82 and the previous owner had replaced th battery with one for the L-48. The L-48 battery has significantly fewer CCA and the difference in cranking speed with the correct CCA on the L-82 was stunning.
