Need help fixing Odometer
Old Nov 2, 2006 | 09:49 PM
CCrane65's Avatar
CCrane65
Default Need help fixing Odometer
My odometer and trip meter don't work but the speedo does. Can anyone tell me how to fix them?
Old Nov 2, 2006 | 10:24 PM
wombvette's Avatar
wombvette
The gear inside the head is worn out. You will have to remove it and send it to a speedometer repair shop. You will have to specify that they use a metal gear or you will have the same problem very shortly. O,r if the plastic gears are used, remove the trip part, then it might last.
Old Nov 2, 2006 | 11:01 PM
CCrane65's Avatar
CCrane65
Thanks wombvette.
I've seen a few Corvette parts suppliers carry odometer gears in both plastic and metal. I was hoping I might be able to repair it myself. I'll have to look at it when I get it out.
cc
Old Nov 3, 2006 | 12:58 AM
wombvette's Avatar
wombvette
Its possible that you can replace the gear and it still be calibrated, especially if you stay with what is in it now. But I have noticed in the past that if you replace it with a different material, for some reason it changes the calibration.
Old Nov 23, 2006 | 09:08 PM
carnutbob's Avatar
carnutbob
Default DocRebuild sells gears
Getting the pointer off without breaking the small shaft running up to it is nearly impossible. I broke mine trying, so I don't know if I will be able to fix that or not, because I don't know if anyone sells that part. DocRebuild.com has the worm gears. 1-800-8669-DOC or 203-366-1332.
I would recommend getting an estimate from someone like Corvette Clocks by Roger 901-664-6120 or 800-752-3421 for orders.
Old Nov 23, 2006 | 09:39 PM
CCrane65's Avatar
CCrane65
Thanks for the advice carnutbob. I know I've seen needles for sale so you shouldn't have any trouble getting one.
I'm kinda thinking maybe it's best to buy a working speedo in good condition and swap them. Then I can sell mine as is to offset the cost to some degree.
I'm surprised that no one offers a rebuild service with a core charge so you can order the replacement, install it and return yours to get your core charge back.
cc
Old Nov 23, 2006 | 10:08 PM
RMS73's Avatar
RMS73
You don't need to remove the needle to replace the two gears. Try Corvettefaq.com. I believe there is an article there showing how to replace the gears. If not email me. Many years ago there was a post here telling and showing how to replace the gears, I believe it ended up at Corvettefaq.
I replaced both gears two years ago. Easy once out of the dash, it will only take an hours or so to replace the gears.
I got plastic gears from Dr. Rebuild.
Roger
Old Nov 23, 2006 | 11:14 PM
CCrane65's Avatar
CCrane65
RMS73, I found the article. Sound like a very doable project. Guess if I'm going to the trouble of replacing the speedo, I may as well try to fix it instead.
Thank you for pointing me to the article.
While I was there, I found one on adding wider tores to a C3 that was very informative also. I'm going with 255x60s instead of 225x70s.
cc
To Need help fixing Odometer
