2004R Cross Member
Old Nov 3, 2006 | 09:59 AM
78anniversary's Avatar
78anniversary
Default 2004R Cross Member
Has anyone swapped a 2004R into a 78 and used the original crossmember? If so did you have to modify it?
I have searched the forum and found info indicating both ways, that is has been done and that you need the BTO crossmember, so I'm looking for first hand experience.
Old Nov 3, 2006 | 10:29 AM
rosslato's Avatar
rosslato
i did on my 73 & used the stock crossmember, fits perfect. don't know if a 78 is different though
Old Nov 3, 2006 | 10:49 AM
Artsvette73's Avatar
Artsvette73
I looked in the GM parts and illustration manual. Th 68-79 auto crossmember is the same. It appears that you eliminate the small trans suppurt bracket for the th350 and use the two upper holes in the crossmember that the th400 used. The lenght for the 200r4 from the face of the bellhousing to the mount is 27 in. The 400 is 26 15/16. So it appears to be a go. I am doing this for my 77.
Old Nov 3, 2006 | 10:57 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
If the 68 to 79 is the same cross member, then your 79 should have a TH400 rather than a TH350. If so, your crossmember should work fine without modification. The TH350 crossmember won't.
Old Nov 3, 2006 | 04:35 PM
78anniversary
So if I understand this correctly, the crossmembers are the same for the TH350 And TH400, the 350 just has a support bracket that needs to be removed and the 2004R should work?
Old Nov 3, 2006 | 04:57 PM
CA-Legal-Vette
Not quite. The TH400 crossmember works for the 200-4R. The TH350 only works for the TH350.
Old Nov 3, 2006 | 05:19 PM
marshrat99's Avatar
marshrat99
Unless I missed something obvious during my 79 TH350 to 2004R conversion last winter, the 79's TH350 xmember would not work. According to memory, the TH350 xmember holes were about 6" too far forward. I used Bowtie's xmember and was an easy install and highly recommended by me.
Old Nov 3, 2006 | 06:12 PM
mkflanagan's Avatar
mkflanagan
The th350 WILL work I just did a th350 to 200r4 on my 76 but in doing my research I read that in 79 they changed the crossmember and they will not work for the 200r4.Do a search on it you will come up with a good bit of info.
Old Nov 3, 2006 | 06:31 PM
Kalway's Avatar
Kalway
Well I know the '80 crossmember won't work because the TH-350C uses a different crossmember for some odd reason. I wonder if the '78 crossmember is the same as the earlier ones.
Old Nov 3, 2006 | 07:44 PM
Artsvette73
The th350 used a small bracket that bolted to the crossmember by four bolts. Two in front of x member Two in top of x member. If you dump that bracket you will use the two holes in the top of the crossmember. 69-79 thm350 and 400 used the same crossmember. Look through the square hole in the bottom of the crossmember, you will see the two holes you will use.
To 2004R Cross Member
