LT1/M6 swap in a C3
There are a couple problems with a direct swap but it can be done with some changes and mods. Do a search, advanced search including archives, for LT1 swap, and you should get a lot of good threads.
I think the biggest problem is the serp system brackets and accessories won't fit in the C3. You'd have to adopt the brackets from a C4 or third Gen Camaro.
You would have to use a 1993&up C-4 pulley system. I am doing that swap now. Its just work, not hard at all. Yo can e-mail me for more info..
The shifter will be moved up about an inch, and centered in the console.
Gotta use the late model C4 LT1 pulleys so they don't interfere with the suspension.
Gotta get an electric fuel pump and re-do the fuel lines.
Wiring stuff up becomes a little more in depth (like for the key start, guages, and cruise control)
Gotta cut a hole in the transmission tunnel for the shifter, since it's in a different place. (There may be an adapter to make it line up better now though)
You'll need a different crossmember for the transmission.
Make sure you get the computer and wiring harness with it, or some more expenses will come up.
I think that's the gist of it. Megaladon correct me or add more if I'm wrong.
Looks like you're doing it very well, too, by the way.
There are a millon little things you have to do as with any FI swap..
If anyone has questions just e-mail me.. I think I pretty much shown the basic start to a LT1 swap.
I dont know, for what i want it for i believe a C5 would probily be my best bet
Well there are several members that have installed an LS motor in their C3. I think it's a lot harder, but they could tell you that better than I.
stock exhaust on a killer ride
GEN-1 headers work.Nothing hits. Nothing is stock on this car, But its all GM parts
is the hydraulic clutch bracket I had to make.
So MEG, will the pump unit from an '82 fit in a '77 tank? Just upgrade the pump and that's it? Can you suggest a pump?
your doing and they got the right part for you!!
Sorry but what's S&P? I probably know I just can't think of it.
Cool, thanks. I bookmarked it, so I can call them at my leisure. Appreciated.
