Eddlebrock Carb Vac. Lines
Old Nov 4, 2006 | 12:20 PM
kswezey's Avatar
kswezey
5th Gear
Default Eddlebrock Carb Vac. Lines
I have a 72 with a performer intake man. and eddlebrock 650 carb now i am putting this thing back together after two years or so and have completely forgot the vac. line layout for the carb. It has a large port in the rear, a med. sized port front middle, and two small ports on either side in the front. Can someone please help as to where each port goes. Thank you
Old Nov 4, 2006 | 01:01 PM
Duke94's Avatar
Duke94
The big one in the rear will be for vacuum booster. As I recall, the medium size one in the front is bowl vent (and PCV) that goes to the evap canister and the 2 small ones will be for advance and your evap canister. It's been a while since I had this carb on my 78 so hopefully someone else will chime in too.
Old Nov 4, 2006 | 03:14 PM
MELVIN's Avatar
MELVIN
Go to thier website, and bring up thier PDf file on installation instructions. Diagram is on it
To Eddlebrock Carb Vac. Lines
