Pwr Steering slop...
I know this probably has been asked a bajillion times so I apologize in advance
, but I have a lot of slop in my steering, and it's originating from the gearbox. I know you can adjust the screw on top, but I'd like to rebuild it myself (I bookmarked one of the past threads that's encouraging me to do it myself) and do it right, and risk learning something in the process LOL... So where do you order parts from, is there a complete kit available, or some sort of 'performance' or heavy-duty kit maybe? Also, I see there is talk of a Jeep box as well - what are the benefits of the conversion, how much does it cost, what's involved, and what's the wallet damage? And why would you do it in the first place, is it lighter, or a faster response? I guess I wanna know which route is better, rebuilding the factory GM box, or replacing it with a....a.....I'm holding back a hurl here...a CHRYSLER part?
?(look at me, bashing Chrysler when I dirve a Jeep and the old lady drives an LHS.... hypocrit....
There's a lot of down time in Upstate NY while the wind's a-howlin' and the the snow's a-blowin. It's one of the projects I can take my time with on my bench, in the heated workroom, while drinking coffee and watching the Simpsons....
Cheerio,
I'm off for more French roast...
My gearbox has a lot of play in it too. Could be my settings....The torque settings are very low and I did not have a torque wrench that read that low. One day I'll pull it and try to set it again.
My main problem was it was leaking grease out the bottom and looked like crap. I was cleaning up the engine compartment and replacing steering components so figured it was a good time to clean it up as well.
You have to be carfull adjusting the top screw or you can damage something.
This will help you.
http://69.253.166.197/corvettes/vett...%20Rebuild.pdf
rg
rg
The gears on these boxes have been wrecked over the years primarily from incorrect adjustment rather then wear.
This should help you.
http://forums.corvetteforum.com/show....php?t=1345411
Is there a more substantial kit I should be using?
Because, of course, my personal, at-home lathe and bushing-machines are broken....
