SS exhaust system?
Old Nov 6, 2006 | 12:38 PM
rick1500's Avatar
rick1500
Default SS exhaust system?
Anyone have any experience with this system?
http://www.ecklers.com/product.asp?p...dept%5Fid=1267
I noticed it is less than half the price of SS systems I've found elsewhere.
Also, anyone know how it compares to the aluminized system Corvette Central sells for almost the same price?
Thanks!
Old Nov 6, 2006 | 01:03 PM
jnb5101's Avatar
jnb5101
i just installed a welded aluminized system from dr rebuild. not a hitch. it fit perfectly. it came with mufflers. do the other systems have mufflers?
Old Nov 6, 2006 | 01:12 PM
rick1500's Avatar
rick1500
The Eckler's SS system does not, but the Corvette Central one can come with MagnaFlows for about $320.
So, the SS system will end up costing more with mufflers, but maybe it's worth it for SS? Anyone have any opinions?
Old Nov 6, 2006 | 01:39 PM
1stC3Vette's Avatar
1stC3Vette
The add reads:
1/2 of the system pictured.
I think you are only getting half of the pipes, that's why it is priced so low.
I am going with the aluminized system from CC next spring.
Good luck,
Dino
Old Nov 6, 2006 | 01:59 PM
rick1500's Avatar
rick1500
Originally Posted by 1stC3Vette
The add reads:
Good luck,
Dino
Oh...right. I guess the "half of what is pictured" part didn't register with me, since I've never heard of anyone buying half a set of pipes. See, I knew it would be smart to run it by the forum first. Thanks Dino.
I guess I'll go with the CC 2.5" set with MagnaFlows hooked up to the ceramic-coated Hooker headers I just ordered. The body is still off right now, so install should be pretty easy.
Old Nov 6, 2006 | 05:10 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Be careful buying from Eckler's. The company has been going down hill recently, IMO.
Old Nov 6, 2006 | 05:56 PM
Twin_Turbo's Avatar
Twin_Turbo
it's 409 titanium stabilized ferritic steel type stainless, not chromium austenitic steel. No wonder it's cheap
Old Nov 6, 2006 | 06:02 PM
MakoShark72's Avatar
MakoShark72
Just received my 2 1/2" aluminized system from Willcox today, no need for SS here in W Washington. Looks to be good quality. Included "performance" mufflers (not welded), and clamps. About $270.. Install tonite after new fuel tank goes in. Might be running by tomorrow!!!!!
Rob
Old Nov 6, 2006 | 06:28 PM
1stC3Vette's Avatar
1stC3Vette
If you can wait, CC offers discounted shipping on exhaust systems. I don't think it is going on right now, but will probably resume in the next few months. I am going to jump on the sale when it happens. I won't be driving mine until spring anyways.
Good luck,
Dino
Old Nov 6, 2006 | 06:40 PM
rick1500's Avatar
rick1500
Good luck,
Dino
CC's exhaust website is advertising $25 shipping on complete systems right now...are you saying they'll go cheaper than that if I wait?
Old Nov 6, 2006 | 07:36 PM
aussiejohn's Avatar
aussiejohn
Default Stainless expansion problems????
G'day,
I read an article in a recent Covette publication where they said that the problem with stainless is that it expands and contracts (with engine running/not running) much more than aluminised mild steel and that if you fit a stainless exhaust, you should be prepared to do a lot more adjusting hangers, brackets, etc.
Anyone have any knowledge on this???
Regards from Down Under
aussiejohn
Old Nov 6, 2006 | 10:13 PM
ThunderMaker's Avatar
ThunderMaker
I just ordered and received most of my dual kit from CC. I say most because their not sure where my intermediate pipes are right now. Since this is a kit, which implies most average folks can install it, it sure would be nice if they made them to bolt up to headers. I got my headers on this past weekend and plan to put the pipes on tomorrow. I ordered the alum steel from these guys because I really liked their tech guys who answered my questions.
Old Nov 6, 2006 | 11:32 PM
rick1500's Avatar
rick1500
I know what you mean about installing with headers. I'll also be putting my CC kit on with headers in the next few weeks. I hate the thought of hacking up my brand new set of pipes...oh well.
Old Nov 6, 2006 | 11:38 PM
rick1500's Avatar
rick1500
Originally Posted by aussiejohn
G'day,
aussiejohn
I also read that on CorvetteCentral's site:
http://www.corvettecentralexhaust.com/aboutus.htm
I guess modern cars can get away with it because they use flex couplings? I have no idea otherwise...
Old Nov 7, 2006 | 01:26 AM
noonie's Avatar
noonie
As usual, one has to sift thru the marketing hype.
Does stainless expand a lot more than aluminized steel. I have heard that a stainless system will grow 1 ½” in length when it gets hot. Is this true?
In a word, NO! If stainless systems expanded as much as some olds wives tales would lead you to believe, then how would so many OEMs use it and not have problems? The key is to look at a property of the material called the coefficient of thermal expansion (COTE-Geek terms for how much the material will grow when it gets hot). For mild steel the COTE is:...Looking at an exhaust system that is 84 inches long, and whose temperature will change 600 degrees F, on average, for mild steel:
change in length=.3157 inch.
For stainless: =.473 inch
So that is only a difference of .1573 in. or a little over 1/8 inch.
Here is a link for what they say on their lifetime waranty stainless.
http://www.stainlessworks.net/cart/faq.php
Here is some more info:
Typical 1010 carbon (mild) steel conducts 219% more heat per foot than do the types of stainless steel we use in header fabrication. By contrast, quite a bit more heat stays inside the stainless header tubes and does not get passed into the surrounding air. By not allowing the contraction of the cooling gases as they flow down the tubes, more exhaust velocity is retained which promotes better scavenging at the collector. This retention of velocity increases the overall header efficiency.
This can be found here with other links
http://www.burnsstainless.com/TechAr...s_article.html
and a more general link
http://www.burnsstainless.com/TechAr...harticles.html
Interesting info on the above sites. Take a look at the header on the Inconel link
As I said it's hard to sift thru all the claims, but I suspect that profit margin and sales has more to do with promoting a product to a general public with a budget in mind, thus the info may be swayed that way.
Aluminized=more sales, more profit
Stainless=less sales, smaller market, much higher price
Old Nov 7, 2006 | 07:20 AM
1stC3Vette's Avatar
1stC3Vette
I haven't checked in the last week or so. The cheapest I had seen was shipping for $20.00. Not that it is much different than $25.00. Thanks for the heads up.
Dino
Old Nov 7, 2006 | 09:19 AM
Jims79's Avatar
Jims79
That's a very low price for a SS system. You can't go wrong if you buy it even if it doesn't hold up your out less then $300. Go for it and let us know if its a good deal. When I put my 2.5 aluminumize duals the tech rep talked me out of the SS which was three time the amount. He said it really wasn't worth that much more. Maybe the price is coming down.
To SS exhaust system?
Old Nov 7, 2006 | 11:05 AM
GUSTO14's Avatar
GUSTO14
I installed an Allen's SS exhaust system on my 1973 in 1991... It was not cheap, but has been halfway around the world and back and it still looks terrific. (Many of the vendors carry the Allen's system.)
I've never experienced any problems with the system related to expansion/contraction, or any other reason for that matter. Buy it once and forget about it in my opinion. I did remove it about 4 years ago to do a frame-off on this car and reinstalled it as before. Oh, and it sounds very nice, authoritative, but not loud and certainly not tinny...
GUSTO
Old Nov 7, 2006 | 11:15 AM
Twin_Turbo's Avatar
Twin_Turbo
Stainless does not sounds tinny..the only drawback is weight, expansion is really not an issue. Nothing more beautiful than a hand made tig welded stainless exhaust (from weld els and straight sections) IMO.
Old Nov 7, 2006 | 12:17 PM
C3 4ME's Avatar
C3 4ME
I know I guy who had full stainless exhaust on his stock 340 horse 62 Vette and removed it to sell this past Carlisle. His did sound very tinny, which was the sole reason for ditching it, it just didnt' sound right. I think he went with aluminized pipe, but whatever he put on it, it sounds like it's supposed to now.
