headlight help
Old Nov 6, 2006 | 06:52 PM
philbshelb's Avatar
philbshelb
Default headlight help
i have a 74 big block and have been working on my lazy headlights. they used to take a few minutes to open and a lot more to close. i just replaces the check valve, filter, overide switch and two relays, my problem now is when i start the car the headlights open and then close on their own. does anyone know what the problem could be or did i mess something up. the headlights do work a lot faster than before.
thanks alot for any help.
Old Nov 6, 2006 | 09:27 PM
wombvette's Avatar
wombvette
Usually an indication of a bad check valve, but you said you changed it. I think I would check to see that it is good.
