Is it common to get new push rods when a rebuild is taking place? Can I go with the stock ones? Do I need some extra hardened ones?
Specs
4 bolt main block bored 60 over
Vortec heads ported, polished new stainless 202 valves
should make 10:1 comp
edelbrock performer intake,holly 750
Comp cam & lifters xe 268h
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i didn't and wish i had......i will be putting new ones in this winter...you are using new rocker arms correct? i will be using the pushrods from CC that are the ones they spec for my cam (xe268) i think they are the entry level replacement stock ones....i don't believe they are anything fancy
Thanks for the responses I will be using comp roller rockers along with their cam and stronger springs so I better go with some better push rods.
Get a pushrod length checker and figure out the correct size needed for proper rocker geometry and buy that size pushrods new. Not worth taking a chance as I am sure with the vortech heads, different cam, different rockers and different lifters your valvetrain geometry is different than stock. Comp pushrods are what I used
Chevrolet used standard push rods in combination with these springs and they worked fine. If your springs are tougher than that, though, obviously you'll need some good ones. Do as 63mako said, though, check the length and such and make sure to get em right. The right size and strength pushrods will last you forever, as long as nothing goes boom!
Thanks for all your help my heads have been reworked with larger valves and springs good to 520 lift so I ordered the comp pushrods that will match the lifters and cam.
Originally Posted by Kalway
For reference, here are the specs for standard Z28 valve springs.
Good choice! Out of curiousity, what was the damage to your wallet on em? I personally hate seeing pushrods go for more than $6 a piece, insane how a little piece of steel can possibly be worth that much, in my opinion.
