Bad day, engine seized. Thoughts please?
Old Sep 22, 2001 | 11:39 AM
paso's Avatar
paso
Default Re: Bad day, engine seized. Thoughts please? (dogboy)
That was sure a bad movie. But the facts will come out clear on disassembly. I think 427V8 is going to be bang on on some of his guesses the mainbearings were likly worn out causing low oil pressure at idle. That is why bubba had the idle at 1800 as there was likly some oil pressure @ 1800 rpm That would elimanate the oil pump being bad or pick up tube fallen off ( which I have seen both ) but if the bearings are bad JUST simply worn out you'll get all the symptoms discribed. My bet when you pull the motor apart is you'll have worn out bearings.
