Blowing Fuses
Old Nov 8, 2006 | 11:15 AM
79vetter's Avatar
79vetter
Default Blowing Fuses
My 79 has decided to start blowing the fuse the controls the interior lights. As soon as I put in another- it blows...this blows
What is the best way to track these kinds of issues down? I understand that there is probably some wire that is loose or crimped Or something else. Is there a systematic approach to these?
Old Nov 8, 2006 | 11:33 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
One of the wires in the circuit probably has a dead ground. Just follow the wires from the fuse box and carefully look for a bare wire. You should get this fixed asap-fire and fiberglass don't mix.
Old Nov 8, 2006 | 02:09 PM
icanfixitforyou's Avatar
icanfixitforyou
Have you had either the speedo/tach gauge cluster or the center gauge cluster out? They both have flimsy mylar printed circuits on the back of them that also supply current to the dash/courtesy lamps. It may be that one of these has shorted to ground.
Old Nov 8, 2006 | 02:40 PM
SIXFOOTER's Avatar
SIXFOOTER
Also look at the light delay timer behind the pass side dash, it is powered off that fuse too
To Blowing Fuses
