sbc OHC ???
Old Nov 9, 2006 | 01:53 AM
hensen1954's Avatar
hensen1954
Default sbc OHC ???
Anybody ever done an overhead cam set up for the sbc or bbc ??
Should make it chat along quite well...........
Old Nov 9, 2006 | 02:57 AM
Kalway's Avatar
Kalway
Not quite OHC BUT it gives you the same effects by giving you twice as many valves.
http://www.araoengineering.com/Chevy/chevysmb.htm
Old Nov 9, 2006 | 03:00 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There's the good ol' LT5...designed by Lotus, built by Mercruiser. The LSx engines give as good or better performance from a traditional pushrod design, though.
Old Nov 9, 2006 | 03:03 AM
Kalway's Avatar
Kalway
Well the LT5 did the same power with less cubes (5.7L vs. 6L). However, it's not like it's hard to get a 5.7L SBC Gen I, II, or III to 400hp, either.
Old Nov 9, 2006 | 06:35 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
The new northstar 4.6L VVT motor will probably fit in the car. If 320hp is enough for you. Cams are going to be difficult though.
Old Nov 9, 2006 | 12:19 PM
hensen1954's Avatar
hensen1954
Wow - those are quite horny !!
Old Nov 9, 2006 | 02:01 PM
gorrie16's Avatar
gorrie16
I loved those till i saw the price for a BBC. 20k ouch.
Old Nov 9, 2006 | 02:46 PM
Kalway's Avatar
Kalway
I saw a set of heads similar to those on ebay once for an LT1 and they were going for quite a pretty penny, too.
Suprised no one else has picked up on the design and used it.
Old Nov 9, 2006 | 07:50 PM
gerry72's Avatar
gerry72
Everything has been done to the SBC. Yes, there was an OHC kit for it back in the early 70s. There have also been canted (not SB2) heads, three valve, and hemi heads. You should be able to turn something up through Google.
To sbc OHC ???
