Winter Storage
Old Sep 21, 2001 | 10:08 AM
Bond007's Avatar
Bond007
Default Winter Storage
In a couple of months I will be putting the Vette away and here is my question. Does it hurt the car to put it up on blocks a couple of inches off the ground or should I leave it on the tires??? :confused:
Old Sep 21, 2001 | 10:27 AM
john's '81 mouse's Avatar
john's '81 mouse
Default Re: Winter Storage (Bond007)
If just normal winter storage (for only a few months), I'd just let it set on the tires after making sure they are inflated to something like 35 lbs. psi., no need to put on blocks for that short a time period. I'd be more concerned with supporting entire weight of car on blocks at points on the frame not intended to carry this much weight for a long period of time.
Old Sep 21, 2001 | 10:31 AM
Neo Fender's Avatar
Neo Fender
I've heard that modern tires don't flat bottom, but I wouldn't use my tires to guinea pig that theory.
I have a driver, so I probably won't do anything drastic this winter. I'll probably just start it up a couple of times a month and take it around the block, weather permitting. If I get snowed in, I could just pull the car backward or forward a foot or two inside the garage, to keep the tires from becoming square :rolleyes:
Old Sep 21, 2001 | 12:10 PM
Leos 81's Avatar
Leos 81
I didn't do anything special to my '81 for storage last year and had no problems, but if you're concerned, I know that Ecklers and a few other Vette parts specialists sell these foam matts for your tires that you just drive up onto and it's supposed to prevent flat spots by evenly distributing the weight of the car to the entire bottom part of the tire. I'm not sure what they cost, but I don't think it was too expensive.
Also, you could always the jack the car up a little and put supports under it, but I wouldn't jack it where the tires are not touching the ground. Just jack it high enough to take some of the burden of the weight off the tires.
Old Sep 21, 2001 | 12:16 PM
Koz
Guest
Posts: n/a
Default Re: Winter Storage (Leos 81)
You could jack up each side of the car enough to rotate the tires 1/4 turn and then set them back down. I plan on working on my rims over the winter so I'll have each off at least once. Anyone have a good way of cleaning the aluminum rims? Any buffing type tools available?
Old Sep 21, 2001 | 02:58 PM
68shark's Avatar
68shark
Default Re: Winter Storage (Koz)
I inflate tires to 40 psi....start car regularly, move out into driveway, let warm up (if no salt/roads dry, take for a short "spin"), pull back into garage. Had to remember to adjust tire pressure down to 32 in spring. Other than that, no special preparations at all. Oh yes, I use 20W50 oil normally. I change to 10W30 late fall so engine will start with less effort/wear in cold weather.
Old Sep 21, 2001 | 03:03 PM
Biker's Avatar
Biker
Default Re: Winter Storage (68shark)
Blocking up the car for long periods stresses the frame. All you need to do is stabilize the gas, trickle charge the battery once or twice a month. While a cover is optional, they do help keep the car clean.
Old Sep 21, 2001 | 04:44 PM
454Big's Avatar
454Big
Default Re: Winter Storage (Biker)
I disagree!
I have my car on the hoist since I guess November last year - no sagging, no gaps on the body - nothing!!!
You must use the correct points to put the hoist under - then there is no problem.
I even have a Big Block in the car! So there is more weight in the front!
My car is still perfect in all gaps even after 10 month "on air"..... :jester
Reason for this is not only storage, but a major overhaul of suspension and other components.
I´m currently thinking of lifting the body from the frame.......
But because I´m limited in time I guess it is not a good idea at the moment.
....we will see as time goes by......
Old Sep 21, 2001 | 10:09 PM
Bills17n72's Avatar
Bills17n72
Hey go to the home improvement store ,and buy a sheet of styrophome and break it in 4 pieces ,back the car up 2ft. lay the styrophome down and drive the car on top of it , and that will keep your tires soft.Sorry for the goofy spelling!
Old Sep 22, 2001 | 10:50 AM
Dwayne 76's Avatar
Dwayne 76
Oh, I'd love to hear any ideas on cleaning the aluminum rims. As I have the same problem. :cheers:
Old Sep 23, 2001 | 02:04 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I have stored my car every winter for 6 years, I drive it into the garage and lock the doors.
I have seen no ill effects on my car I just take the battery inside and bring it back out to start
it once a month and if it's nice and dry I'll take it around the block.
To Winter Storage
